Alarm and dead locks not working,...2.2 DTI
Started by diggerbuff, 21 February 2012, 20:51:08
diggerbuff
Hi still got the problems with the Alarm not setting and no dead locks coming on,.only the central locking is working with the key or fob,.I Would appreciate any help............Cheers Mike.
freecall666
ask if any one near you can have a look with a tec2, have you check all the fuses...
Solar charger fitted.
If not Broke dont fix it..
fergy
Hi  not sure if this would help you but on the same type of Omega, I recently pulled the wrong fuse (14 iirc)  whilst working on the car. Everything appeared fine until I tried to lock the car having arrived at tesco. It produced exactly the symptoms you describe.
The electrical gurus will be along just now to tell you what fuse 14 under the steering wheel does.
Fuse 14:
Ignition switched supply to:
Heated washer nozzles
Cigarette lighter socket
Climate panel
Alarm / Central locking ECU
Rear screen blind
A common failure as it's easy to drop a coin into the lighter socket or overload it. Would have thought he climate panel would be dead, though. Worth a try. :y
diggerbuff
Thanks for  the reply's,.will again check the fuses also no problem with the climate panel,and it would be nice if i could find somebody that had a tec2 in the Merseyside (St Helens) area,..................Cheers Mike.
