Author Topic: thermostat part number  (Read 1355 times)
martin42
« on: 22 February 2012, 19:27:19 »
got engine stripped down,thermostat removed from housing but having problems getting hold of this on its own from a motorfactor,can any please supply a reference number or part number,need to get this fitted asap,thanks  ;)
Re: thermostat part number
« Reply #1 on: 22 February 2012, 20:38:58 »
Thermostat, 90502201
That's the VX Part number for the V6...
martin42
« Reply #2 on: 22 February 2012, 20:41:28 »
thanks but thats for a complete new housing and thermostat,just want the stat part number or equivalant
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #4 on: 22 February 2012, 20:44:17 »
Ah, Gotcha.
I wouldn't know that. For what they cost, it's really not worth messing with, trying to fit a new stat into an old housing...
fiend61
  • york
  • each to their own
« Reply #5 on: 22 February 2012, 20:47:49 »
http://www.ctautopartsltd.co.uk/CatGroup.aspx?NoCache=634655402274019260
in your home town aswell  :y
THERMOSTAT More QTH600K 00-01 1 9.43       (OPENING TEMP(deg C):92 HEIGHT (mm):35 DIAM 1 (mm):40 DIAM 2 (mm):30 w/o HOUSING, w/SEALS)
« Last Edit: 22 February 2012, 20:49:42 by fiend61 »
« Reply #6 on: 22 February 2012, 20:53:30 »
Try GSF autoparts mate as well if you haven't already . Telford way  :y
martin42
« Reply #7 on: 22 February 2012, 20:57:45 »
due to csa making me live on such little money i have to do somethings on the cheap,just pisses me of that i only want the stat,housing is still perfect,will try gsf 2moro Steve,forgot about them  :y
Drewomega
  • Aviemore and Mallorca
    • SKODA Octavia Scout 2.0
« Reply #8 on: 23 February 2012, 14:34:02 »
If you are buying the thermostat make sure the housing is the same. I had to cut the 2 bolts to fit the new stat housing I bought recently. Oh! and don't forget to replace the 2 "O" rings.  :y
I'm always last in the office in the morning but I make up for it by leaving first.
martin42
« Reply #9 on: 23 February 2012, 18:12:32 »
all done and sorted,new stat from unipart,rubber gasket,transfer pipe from vx dealer,im not in no hurry to do another 1 tho lol :y
« Reply #10 on: 23 February 2012, 18:16:47 »
Nice one , glad you got it sorted  :y
Nice easy job  :-X
martin42
« Reply #11 on: 23 February 2012, 18:19:49 »
id do it again,but no rush at the moment.just got to top up coolant before i go out later for a drive and see how it goes,il be over saturday mate will let you know what time sat morning  :y
« Reply #12 on: 23 February 2012, 18:23:46 »
Ok thanks  ;)
