Author Topic: 3.0l or 2.5l  (Read 1567 times)
prestigesec
  • Wirral
3.0l or 2.5l
« on: 27 March 2008, 13:00:15 »
Which is more reliable 3.0l or the 2.5l keep hearing rocker covers leak all the time on the 2.5 is this true? Also is there much difference in fuel economy? Thank you in advance for help Regards Steve
ians
  • Reading
Re: 3.0l or 2.5l
« Reply #1 on: 27 March 2008, 13:17:03 »
They are basically the same block.  No difference in cam cover seals - there's just more 2.5's around.
prestigesec
  • Wirral
Re: 3.0l or 2.5l
« Reply #2 on: 27 March 2008, 13:18:14 »
Cheers is there much difference in economy between them?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: 3.0l or 2.5l
« Reply #3 on: 27 March 2008, 13:20:10 »
Cam cover gaskets leak on both the v6 motors if
 A= They have been fitted wrong
 B= They have used non vx parts
 C= The breathers are blocked and crankcase pressure blows them.
 D= The cam covers are warped due to being tightned down to much.
 2.5 IS VERY FRUGAL WITH THE FUEL AND GIVES GOOD PERFORMANCE
 3.O IS NOT SO GOOD ON FUEL, BUT BOY WILL IT PUT A SMILE ON YOUR KISSER :y
« Last Edit: 27 March 2008, 13:22:35 by ffcgary1 »
Jaguar XJ6
bigdods
  • Brackley
Re: 3.0l or 2.5l
« Reply #4 on: 27 March 2008, 14:00:55 »
I've had both. 2.5 is better on the fuel by a few MPG, 3.0 is noticeably more responsive on the throttle but I'm not sure its enough of a difference to warrant the difference in fuel economy. Next time I'm going to try for a 2.6.
prestigesec
  • Wirral
Re: 3.0l or 2.5l
« Reply #5 on: 27 March 2008, 14:50:16 »
How is the 2.2 petro; in all this would imagine it being quite slugish for the weight of car is this true?
ians
  • Reading
Re: 3.0l or 2.5l
« Reply #6 on: 27 March 2008, 17:07:02 »
Well I had a 2.0 and it was quite responsive but nowhere near as refined as the V6's
