Poly bushes
Started by astroblaster, 24 February 2012, 01:05:42
astroblaster
Hi all which are the best poly bushes to buy to rebush the front wishbones.
thanx john :y
Do it today cause tomorrow it might be Illegal
Zippy2012
Quote from: astroblaster on 24 February 2012, 01:05:42
thanx john :y
That makes 2 of us!! need mine doing too mate!
Michael2.6
I find that these polly bush type you gain tighter chassis control but refinement invariably suffers
That is just my opion
"Tighter chassis control" is a refinement, is it not?
geoffr70
Quote from: chrisgixer on 24 February 2012, 20:57:53
i think he means less comfort, that's certainly what I've noticed after I polybushed my front end. Less sloppiness but less comfort
TC and BnQ Trade holder.
Cant say I noticed any difference in comfort when I polybushed either of mine. In the case of TBE, it highlighted a load of other problems though...
thanx john :y
However, poyflex only do the front bush. So if the reaward bush has failed you need to look at either pressing new rearward bushes in and fit polly fronts, or fit new arms then polly those, either from new or later if the front bush fails.
Tbh, new wishbones would be best. ;)
geoffr70
Quote from: TheBoy on 24 February 2012, 22:07:18
Like what? Back end wandering and back end bump steer by any chance?
Quote from: geoffr70 on 24 February 2012, 22:42:36
original rear subframe bushes?
geoffr70
Quote from: chrisgixer on 24 February 2012, 22:51:04
1 yr old,  fitted to correct orientation, not a shiiite make either
donuts anyway
Quote from: geoffr70 on 24 February 2012, 22:56:12
donuts anyway
Febi? I have them of so, similar issue. Cross winds mostly though.
geoffr70
Quote from: chrisgixer on 24 February 2012, 22:59:59
donuts anyway
Yeah that's it i think, couldn't think of the name and it's definitely not Lemforder. I don't even know if they do donuts. Not in winds, mainly over bloody stupid raised manhole covers and bumps in the road. I might eventually get geo done, hopefully that will ease it a bit.
Quote from: geoffr70 on 24 February 2012, 23:03:22
donuts anyway
Solid sections pointing at the dif?
