Author Topic: Shaving  (Read 15763 times)
Shaving
« on: 26 February 2012, 13:08:24 »
I'm about to change shaving methods again...
I started with Gillette razors, and seem to alternate their current razor with an electric shaver, using top of the range shavers from Phillips, Braun, and lastly Panasonic (which was the best I'd used).  Until my face gets fed up, or shaver wears out and I change again.
Currently on Gillette Fusion...but my skin has had enough and its time for a change.
Fancying a go at a traditional Double Edge razor, and blade selection such as :
http://connaughtshaving.com/merkur33c.html
http://connaughtshaving.com/popular.html
Not too sure on getting a cream and brush...so sticking to gel for the moment.  Much reduces initial outlay, may have a go depending on how I get on.
Everyone who uses a DE system seems to be a real fan and wont consider anything else.
Seems to be a better shave, and huge cost saving compared to cartridge razors.
Anyone else use this method....any advice?
Re: Shaving
« Reply #1 on: 26 February 2012, 13:12:48 »
any advice?
Buy plasters in bulk?
(I jest - never been brave enough to try a traditional razor.. have had the odd professional shave done with a cutthroat - brilliant, if a little scary!)
I stick to running a pair of clippers over mine every few days, but then I don't need to stop anywhere as the hair on my head is just as short non-existant. ;D
Re: Shaving
« Reply #2 on: 26 February 2012, 13:14:52 »
Always fancied a cut throat shave...never got around to it though.
Good point though, will add a styptic pencil to the order.
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
Re: Shaving
« Reply #3 on: 26 February 2012, 13:23:37 »
Use to use one of those in my teens, made a right mess of my face and ended up getting rashes, so moved on to electric shavers, strange thing is now, many moons later, electric bring me out in a rash, so now I only wet shave, when I can be bothered, tried most, now generally only use Bic Disposables, the Orange Sensitive type, and Gel, works for me.
A tip I was given years ago from a Barber is not to use Hot or Cold water when Wet Shaving, only luke warm?
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Shaving
« Reply #4 on: 26 February 2012, 13:50:38 »
What is this "Shaving" of which you speak?
TuBy's new whipping boy.
hercules
  • sunnyudders
Re: Shaving
« Reply #5 on: 26 February 2012, 13:59:21 »
i hate shaving with a passion,the only razor i can use is gilette sensor.if i use owt else its as if somebody has slit my throat the amount of blood that comes out and i can only shave once a week.these women have got it easy(they dont have to shave till theyre in their fifties  ;D )
Re: Shaving
« Reply #6 on: 26 February 2012, 14:44:46 »
;D ;D ;D ;D ;D
bored bigyin54
  • south wales
    • black beast
Re: Shaving
« Reply #7 on: 26 February 2012, 15:08:10 »
any advice?
some of us still got the hair on top never had short hair must be cold in winter just joking
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
Re: Shaving
« Reply #8 on: 26 February 2012, 15:09:48 »
I have had same prob with skin and have found the Gillette Fusion with no gel or foam just when wet when in the shower.
It is the gel or foam that was irritating my skin  ::)
Philishave recheargable for none wet shaving not had probs for years  8)
Plomien
  • Swansea
    • Landrover Freelander TD4
Re: Shaving
« Reply #9 on: 26 February 2012, 18:50:25 »
use king of shaves shaving oil or gel better than foam :y
Re: Shaving
« Reply #10 on: 26 February 2012, 18:57:24 »
I use a Philishave. Then I just splash on half a pint or so of Old Spice/Denim/ Brut/ Hai karate and the girls are putty in my hands.... ;)
paul.lovejoy
  • Ramsgate Kent
    • wife mad 2.6 cd estate
Re: Shaving
« Reply #11 on: 26 February 2012, 18:59:02 »
cant be done with shaving just clip it back every now and again and trim up....only problem is people do think at times they are talking to my arse ::) ;D
Re: Shaving
« Reply #12 on: 26 February 2012, 19:03:06 »
I find it helps to wash and lather beard thoroughly first to soften the bristles, keep beard wet, apply foam, then shave with the grain loosely.
Then wet hands and use the remainder of foam on face to rub in/re lather and re shave against the grain finally.
Still can't shave every day though. Gillette sensor turbo(?) seems to suit me best. I have the orange fusion ones currently which don't seem as good. Although I think the orange blades are a cheaper spec than came with the fusion I bought. :-\
Can't get on with electric shavers. Too many lay flat bristles and seem to sting and pull more.
Taxi_Driver
Re: Shaving
« Reply #13 on: 26 February 2012, 19:08:53 »
Have you tried a braun series 3 ?
Its my current leccy shaver.....designed for people who dont shave everyday and its waterproof, so can be used in the shower if you wish.....i find it doesnt pull hairs even if i havent shaved for a few days.....however it probably takes slightly longer to shave than most leccy shavers as you sometimes have to go over the same area several times to get a smooth shave  :y
Re: Shaving
« Reply #14 on: 26 February 2012, 19:15:49 »
Last foil razor I had wasn't any better, and the foil broke and cut me chin. Although it wasn't a Braun. Pillishave no better. Not sure it's worth the expense of trying a third electric razor tbh. :-\
