Author Topic: 2.2 TD 2002 water pump belt replacement  (Read 1674 times)
MattA1974
    • Omega 2.2 TD
« on: 26 February 2012, 18:23:44 »
Hi,
I have managed to change my alternator but I'm now struggling with the belt. I have looked at a picture of the belt position. I have managed so far with working from the top.
The T wheel can move about 2cm (1inch) but there doesn't seem to be enough slack to fit the belt back on. Any ideas?
Thanks
Matt
bored bigyin54
  • south wales
    • black beast
Re: 2.2 TD 2002 water pump belt replacement
« Reply #1 on: 26 February 2012, 19:13:10 »
ask rob g
MattA1974
    • Omega 2.2 TD
« Reply #2 on: 26 February 2012, 19:26:12 »
Thanks.
Who is Rob G?
innarightestate
« Reply #3 on: 26 February 2012, 19:41:35 »
hi matt i have just changed my belt on the exact same engine i remove the undertray to give me better acess to the tensioner .you have to loosen the tensioner  bolt with a torx socket then using a 19mm socket with a bar pushing it anticlock wise fitting the belt over the tensioner pulley last .ps only use belt part no 6pk 1902 iif you have a.c .i also change the tensioner as well as a precauion i bourt both parts from a vaxhall dealer as i didnt want to risk pattern made parts cost a little more but garented parts. hope this helps geoff cheers
MattA1974
    • Omega 2.2 TD
« Reply #4 on: 26 February 2012, 19:50:34 »
Thanks.
I haven't changed the belts. You think I ought to?
innarightestate
« Reply #5 on: 26 February 2012, 21:20:27 »
hi yes i would fit a new belt as the old one might started sqeaking  :) cost of belt not that dear ok.cheers geoff
