Author Topic: Knock sensors  (Read 1240 times)
Knock sensors
« on: 27 February 2012, 00:04:43 »
What are the possible side effects of running with one unplugged :-\. Currently idling/running ok, but...
1. spanner light on, eml off.
2. codes are: 0300
                   0306
                   0430
                   0420
and unsurprisingly 0330.
Still trying to sort the rough running/idle, and got to thinking that the knock sensor might be causing the issue if the valves on pot 6 aren't quite closing as smoothly as they should :-\
« Last Edit: 27 February 2012, 00:11:05 by taxi al »
tango
  • brum
Re: Knock sensors
« Reply #1 on: 27 February 2012, 01:50:43 »
im sure the knock sensor is used to set the timing but maybe some of the senior members can shed more light
Re: Knock sensors
« Reply #2 on: 27 February 2012, 08:42:21 »
Big power loss as the ECU backs the ignition timing right off!
Re: Knock sensors
« Reply #3 on: 28 February 2012, 04:33:13 »
Currently only side effect seems to be spanner light :-\ will still pull 0-60 in 7 secs so no apparant loss of power, and seems more economical to boot ;)
What are the symptoms if a knock sensor fails/how reliable are they? :-\
Car idles smoothly, even when left idling for a while. Previously after 30 secs or so it would be rougher than a dead badger ::), no starting issues either.
Page created in 0.108 seconds with 16 queries.
