Author Topic: Radweld plus and coolant change  (Read 2802 times)
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
« on: 27 February 2012, 10:03:55 »
I'm about to try Radweld plus to see if that can cure a long term water leak, and going to flush the system out, am I best to add the Radweld before or after the flush.
Cheers, Jon  :y
Jon
Re: Radweld plus and coolant change
« Reply #1 on: 27 February 2012, 10:08:04 »
Best to sling it in the bin tbh.Find where the coolant is coming from and replace whats leaking. ;)
« Reply #2 on: 27 February 2012, 10:09:35 »
Radweld won't cure a leak but will stop it for a while, i'd be more worried about long term effects of having rad weld in your cooling system
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #3 on: 27 February 2012, 10:12:00 »
i will second that pete.  :y
« Reply #4 on: 27 February 2012, 10:12:25 »
I've seen the affects of rad weld  :o
Budget for a new radiator  ::)
Find the leak first, what engine? HBV been checked?
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
« Reply #5 on: 27 February 2012, 10:25:45 »
Thanks all
Its had a new water pump and HBV, there are no visable signs of where it is coming from. I don't want to be throwing any more serious money at it tbh. It's a 2.5 on a 98 plate.
Pete i've sent you a PM
Cheers Jon :y
Jon
« Reply #6 on: 27 February 2012, 12:44:16 »
Ive also seen the affects of rad weld in a 2.5 mig , made it worse than ever so i would say dont do it . There must be a leak somewhere , place a piece of cardboard underneath the car over night and see where any water drops ..that might give you a clue as to where its coming from  ;)
« Reply #7 on: 27 February 2012, 13:04:46 »
Don't throw any more money at it until you have found the cause of the leak.  ;)
The money you've spent already could presumably have been eliminated  if the source of the leak had been accurately identified before replacing parts.
I would strip it down so you can see the thermostat housing, oil cooler cover, etc, then pressurise the cooling system and see if anything can be spotted.
I recently had to replace the seal on a new pattern water pump because it failed (read: turned to plastic) within 2 weeks of fitting so new parts doesn't eliminate them as problems. Unambiguously finding the leak does. :y
Don't touch Radweld unless you want to be replacing the radiator, heater matrix, etc. at a later date.
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
« Reply #8 on: 27 February 2012, 14:09:22 »
Just returned the Radweld to Halfords and bought my lunch with the refund :D
Jon
« Reply #9 on: 27 February 2012, 14:14:02 »
Best thing you could do  :y
amba
  • Medway towns
    • German V6
« Reply #10 on: 27 February 2012, 16:00:39 »
Bet you enjoyed your lunch more than the grief the radwell would have given you long term ;D
Total "Snake oil " IMHO ;D
Page created in 0.025 seconds with 16 queries.
