Author Topic: Camshaft censor keeps burning out  (Read 1372 times)
madswede
  • Glasgow
    • omega
« on: 27 February 2012, 15:23:03 »
Can anyone help car 2.2 petrol auto is burning out cam censor it had an oil leak which coverd the coil pack could this be the cause.
SJKOO01
Re: Camshaft censor keeps burning out
« Reply #1 on: 27 February 2012, 18:18:49 »
Have you cured the oil leak, which I'm assuming was the camshaft cover seal/gasket having become fubbered - Did you use a genuine gasket to fix the leak, if not I should as 'copy' one from your general Autoshop do not tend to last long!
When you say that your cam sensor is burning out, are you replacing it with a genuine one or a cheap one of such as ebay, again genuine one is the way to go.  Also have you got any codes that are indicating an error.
If you can elaborate on exactly what happened initially and what you've done so far, we may be able to help out a bit better ???
madswede
  • Glasgow
    • omega
« Reply #2 on: 28 February 2012, 01:52:16 »
Hi Gooseman the oil leak was cured and when the motor was turned over the cam censor failed and a new GM one was fitted and the same thing happened only ues OE. from dealer. Got me beat love my big motor so realy want to get her well again
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
« Reply #3 on: 28 February 2012, 10:32:06 »
is the engine getting to hot at that point were the sensor is fitted, or the sensor to close to the head.
Solar charger fitted.
If not Broke dont fix it..
madswede
  • Glasgow
    • omega
« Reply #4 on: 28 February 2012, 14:22:09 »
Hi freecall666 car is runing for about 10 seconds then stopping cam censor is showing as prob but can not figure out why this is happening no other fault showing
SJKOO01
« Reply #5 on: 28 February 2012, 18:32:03 »
When you say cam sensor showing as the problem, how do you know this is the issue, have you got a code from which it's telling your it's the cam sensor (post up the code) or are you assuming it's the cam sensor? ???
Out of curiosity, is the sensor the correct one for your year of car, or is it a kit with a modification that you have to do to make it work for your engine, as I know GM did have a batch of these floating around?
Any pictures you can post that may help perhaps, with regards to the cam sensor in place or the condition of the coil pack, etc?  ???
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #6 on: 28 February 2012, 21:49:46 »
Maybe the heat is causing a problem with the wiring or e.c.u.?
Whereabouts is the e.c.u. mounted on a 2.2 petrol?
« Reply #7 on: 29 February 2012, 11:21:36 »
Not unknown for brand new OEM sensors to be u/s straight out of the parts bin! ??? If your new replacement sensor has failed within 12 months of purchase, I would take it back to the Dealer for refund/replacement. The 2.2 ECU lives in the main fuse box next to the battery but I don't think the fault lies there tbh! Have you had a good look at the wiring into the sensor end?, this isn't captive in the sheath at that end & could be getting strained when fitting causing a duff connection. Also worth checking the sensor plug connections for security, cleanliness etc. :-\
« Reply #8 on: 29 February 2012, 12:15:37 »
More interesting question is, what are the symptoms and the codes.
For example, if its camshaft sensor incorrect signal this could be the sensor/wiring/ecu or could also be another factor resulting in an 'incorrect signal' e.g. if the timing was out or there was slack in the cambelt setup.
