Author Topic: F/L Radio/climate panel removal  (Read 10018 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 02 August 2019, 17:12:02 »
Can anyone point me to a guide that shows how this comes out please? My Parrot blue tooth has packed up, and I think is connected somewhere behind it. :y
Re: F/L Radio/climate panel removal
« Reply #1 on: 02 August 2019, 17:34:12 »
Radio out.
Ashtray out, single screw reached over the top.
Two screws behind the top corner of the radiator.
Pull away trim.
Six screws to remove the cage assembly. *
This will require unplugging all the switches, the climate panel and the sockets for the switches...  :y
Shackeng
  • Ramsbury
« Reply #2 on: 02 August 2019, 17:37:00 »
How does the radio come out? I can see 4 holes in the front panel. :-\
« Reply #3 on: 02 August 2019, 17:47:54 »
they have allen grub screws, assuming not lost.
When these are out, normal radio keys can remove the radio in normal way (but in omegas have tendency to stick a bit)
« Reply #4 on: 02 August 2019, 18:20:07 »
These .... https://www.halfords.com/workshop-tools/garage-equipment/fuses-electricals-fixings/halfords-stereo-removal-pins-din-type but they'll bound to be cheaper elsewhere.
but a facelift uses a double din head so they keys are the same idea but wider.
http://www.omegaowners.com/forum/index.php?topic=90646.0
« Last Edit: 02 August 2019, 18:22:25 by Andy B »
« Reply #5 on: 02 August 2019, 18:23:53 »
http://www.omegaowners.com/forum/index.php?topic=90507.0  :y
Shackeng
  • Ramsbury
« Reply #6 on: 02 August 2019, 22:35:20 »
Excellent, thanks Andy et al. :y :y :y
Shackeng
  • Ramsbury
« Reply #7 on: 03 August 2019, 17:01:40 »
Just found this link, https://www.youtube.com/watch?v=bdBR76-y3LI
useful for numpties like me, so might be worth adding to the guide. :y
Shackeng
  • Ramsbury
« Reply #8 on: 10 August 2019, 15:26:39 »
Well, it is sticking a bit. How far in do the double din tools go? I can get mine in up to the bends in the tool. Do they have to be in this far? It seems, with the side switchlites out, I may have to apply leverage to the unit from the sides which I prefer not to do. :-\
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #9 on: 10 August 2019, 15:40:09 »
they do go in a lot , cheap pins are not machined correctly at the tips ,they should catch and grip the springs .
try pulling the pins apart (towards the doors) while wiggling the unit toward you
they are a snug fit
Shackeng
  • Ramsbury
« Reply #10 on: 10 August 2019, 16:05:35 »
Thanks Dave, managed it by wiggling and gentle leverage. :y
However I am now unable to remove the cage. Is there anything other than the Phillips screw at the back holding it in?
« Reply #11 on: 10 August 2019, 17:15:04 »
From memory .... there are various tabs along the front edge of the cage (top, bottom & sides) that hold the cage in situ
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #12 on: 10 August 2019, 18:09:40 »
I don't remember removing a cage ,think my touchscreen cage fitted inside what was there , sorry  :-[
« Reply #13 on: 10 August 2019, 18:14:18 »
Bend it inwards at the centre of each side.
It's a tighter fit than the radio ;)
Shackeng
  • Ramsbury
« Reply #14 on: 10 August 2019, 19:16:10 »
Cheers Al, instead of trying to force it, I used a bigger hammer. ::)
But can I release the aerial plug from the back? Can I hell. >:(
Start again tomorrow. :y
