Pages: 1 2 3 4 [5] 6   Go Down
Author Topic: V6 stalling/poor running  (Read 17175 times)
stuvaux
  • Stourbridge, West Midlands
    • 1999 Mig 2.5V6 CDX Estate
    • Dog Training HQ
Re: V6 stalling/poor running
« Reply #60 on: 25 January 2007, 09:03:25 »
looks like the stripdown will be a job for sunday morning!  (I work nights wed-sat, so not a lot of time till then!)
as far as the hiss goes, it only seems to do that occasionally, and only when i turn the engine off
it lasts for a couple of seconds at most
there are no splits in the inlet pipes
maybe i've loosened/damaged one of the vacuum pipes while messing with the IAC valve.......
stu
Take a look at my Dog Training blog at Dog Training HQ
« Reply #61 on: 25 January 2007, 09:08:28 »
If you look at the rubber piep that connects to the idle valve there shoudl be a smaller pipe which branches off and runs under the plenum......this connects to a small fuel pressure regulator on the fuel rail....is this all intact?
stuvaux
    • Dog Training HQ
« Reply #62 on: 25 January 2007, 09:29:31 »
the small pipe that branches off does have a very small split in it, which i have put some tape over for now...
as far as i can see, it is still connected to the fuel rail
stu
Jones
« Reply #63 on: 25 January 2007, 21:57:50 »
Hi take a look at the brake vacum pump pipe mine had a hole in it. this was cause with my car idling poor
stuvaux
    • Dog Training HQ
« Reply #64 on: 26 January 2007, 08:34:18 »
ok thanks mate
i'll check that properly when i strip the engine on sunday....
thanks,   stu
p.s. the problem has not appeared in the last 2 days, doing only short journeys to and from work..... but i'm expecting it back anytime soon!........
stuvaux
    • Dog Training HQ
« Reply #65 on: 29 January 2007, 11:45:55 »
i stripped the car yesterday, and cleaned all the breathers, checked vacuums etc.
all were intact and connected properly
problem is still there......
on a paperclip test, i am now getting codes 57 & 73
i did clean the iac valve again today though, and left the wiring disconnected when i tested it - so that would explain the 57 code (IAC valve - interruption)
code 73 relates to air flow sensor - low voltage
is this easy to check, or is it possible to clean it?
thanks, stu
« Reply #66 on: 29 January 2007, 18:42:41 »
the 73 may be genuine, or may be a false caused by air leak...
stuvaux
    • Dog Training HQ
« Reply #67 on: 29 January 2007, 19:22:19 »
thanks for all of your help
i've now changed the air flow sensor
there was also a small split in one of the gas pipes that go into the top of the engine, into the inlets
i have also sealed this for now
at the moment the car is running fine again.....i'll just wait and see what happens!........
stu
stuvaux
    • Dog Training HQ
« Reply #68 on: 30 January 2007, 08:27:42 »
hi guys
there is now a leak from the black breather box on top of the engine, causing a strong smell of gas
is it possible to buy the round seal that goes into the plenum
if yes, does anyone know what the part number is?
thanks,  stu
stuvaux
    • Dog Training HQ
« Reply #69 on: 30 January 2007, 10:58:59 »
mark, do you know the part number for the rubber seal for where the breather box on top of the engine goes into the intake?
also, the seals that go into the throttle body?
i've phoned three vauxhall dealers and they don't seem to understand what i'm going on about......no surprise there then....!
thanks,   stu
« Reply #70 on: 30 January 2007, 11:58:29 »
As it happens....yes I do.
Breather bridge to plenum seal (1 off) 90467543 90p+VAT each, retail
Breather bridge to throttle O ring (2 off) 90500983 43p+VAT each. retail
stuvaux
    • Dog Training HQ
« Reply #71 on: 30 January 2007, 12:30:49 »
thanks a lot mark
i have now ordered them from a dealer, i have to pick them up tomorrow
the car is now running fine on petrol, but on gas it has a bad misfire
i think this is due to the air leak from the breather box - as the gas is fed directly through the top of the inlet, so the gas is also leaking from there!
thanks again,   stu
« Reply #72 on: 30 January 2007, 12:40:38 »
The MAF fault code is spot on for an airleak....the engine knows its using a quantity of air but, the MAF is reporting a lower quantity (and hence a lower voltage)
stuvaux
    • Dog Training HQ
« Reply #73 on: 30 January 2007, 12:48:39 »
i have already changed the MAF anyway now - this has definitely made it run better on petrol
once the seals are changed, it should run on gas again (much better, same power, but only 37p a litre!)
problem solved....finally!....i hope...
thanks, stu
stuvaux
    • Dog Training HQ
« Reply #74 on: 01 February 2007, 08:28:32 »
Finally.....the car is running perfectly again!
Thanks a lot to all of you who posted your advice.....particularly Mark, who was very helpful....is there anything he doesn't know about Omegas?
Yesterday, I replaced the breather box seals
The problem on gas was actually some sealant which had set inside the pipe that feeds the gas to each port (of which there are six in total, obviously!), so the car was only running on five cylinders in effect.
Thanks again,   stu   8-)
Pages: 1 2 3 4 [5] 6   Go Up
Page created in 0.033 seconds with 20 queries.
