Author Topic: Driver Door locks problem  (Read 1858 times)
Nick27
  • London
    • Omega 2003
« on: 27 September 2011, 13:24:44 »
Hi Guys,
I have driver door lock problem to my F/L Omega 2.2 CD. it doesn't unlock with the remote but rest of the door unlocks with the remote and driver door locks need to be unlocked manually with KEY. and same case when locking, had to lock the driver door first manually which locks the rest. ???
I thinks its not a motor problem..is it driver door selenoids problem? :(
Thanks in advance for your help guys!! :y
twiglet
  • Norwich, Norfolk
Re: Driver Door locks problem
« Reply #1 on: 27 September 2011, 13:34:01 »
It will be the solenoid in the drivers door that operates the lock. It's a common failure.
I've got a replacement one here that you can have for £12 including P&P mate.  Send me a PM if you want it.
Cheers  :y
« Reply #2 on: 27 September 2011, 15:01:42 »
The door lock mechanisms use a motor, not a solenoid.  :y :y
« Reply #3 on: 27 September 2011, 15:03:32 »
Pedant ;D ;D
« Reply #4 on: 27 September 2011, 15:05:59 »
Pedant ;D ;D
How's that?  ::)
Nick suggested that the problem wasn't a motor problem but a solenoid problem ......... no solenoids in a locking motor though  ;) ;)
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
I feel like a military academy. Bits of me keep passing out.
« Reply #6 on: 27 September 2011, 17:07:35 »
I would go down the repair route ( http://www.omegaowners.com/forum/index.php?topic=90642.0 ) if you are handy with a soldering iron as the replacement switch is only a couple of quid and it's 99% certain that's what the problem will be.
It's always worthwhile giving the lock mechanism a good clean up and lube while you're there though. :y
twiglet
  • Norwich, Norfolk
« Reply #7 on: 27 September 2011, 19:56:50 »
I was referring to the part shown in Kevin's link. I've always called this things solenoids, but if they are actually motors then I stand corrected.
In any case, if you decide you would rather replace than repair, I have one here.  :y
Nick27
  • London
    • Omega 2003
« Reply #8 on: 28 September 2011, 12:56:35 »
Thanks guys for your help and suggestions... Would go for a repalcement rather.... :y
