Author Topic: MFD issues  (Read 1699 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
MFD issues
« on: 14 March 2012, 18:44:42 »
I took the dash panel out to change some bulbs but since refitting the MFD won't work.  it occasionally flickers but never gives a full clear display.  I have checked the plug and no bent pins and it is fully home.  I'm flummoxed, any ideas?  I can't get the radio code in without Tue display  :(
Re: MFD issues
« Reply #1 on: 14 March 2012, 21:05:48 »
New bulbs, or 2nd hand? If 2nd hand, its not beyond the realms of possibility they are all blown.
Make a different with sidelights on or off?
Gaffers
Re: MFD issues
« Reply #2 on: 14 March 2012, 21:18:21 »
Bulbs are working but like I said they occasionally flicker
Re: MFD issues
« Reply #3 on: 14 March 2012, 21:31:42 »
OK, does it make a difference if sidelights on of off?
Gaffers
Re: MFD issues
« Reply #4 on: 14 March 2012, 22:03:41 »
None
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: MFD issues
« Reply #5 on: 14 March 2012, 22:29:40 »
the board may have a dry joint on the pins, may need re solering back on. or the plug wire pins has come away and not connecting properly to the pins,..
Solar charger fitted.
If not Broke dont fix it..
Gaffers
Re: MFD issues
« Reply #6 on: 16 March 2012, 09:16:41 »
Tried 're-wetting' the joints on the plug pins, no change.  Going for replacement :(
Re: MFD issues
« Reply #7 on: 16 March 2012, 09:29:50 »
Can you 'borrow' one from a local member, before buying one, to prove it is MID. Those later MIDs are normally bulletproof.
MID has to match the car spec, though I'm sure Old Man Wood in Alton can assist with tech2 if reqd.  Press and hold both S and R for 3s to see the config on yours.
