Author Topic: knock sensor location.  (Read 3108 times)
« on: 25 March 2012, 13:44:42 »
Done a bit of work yesterday replacing the stat and bridge seals but i have code : 1 - 7 which is knock signal circuit 2.
EML flickering .
Where is the location of this anyone ?  :-\
Re: knock sensor location.
« Reply #1 on: 25 March 2012, 14:51:32 »
plug is down near dipstick. Sensor itself behind engine mount.  Suspect, though, you've forgotten to plug back in.
« Reply #2 on: 25 March 2012, 15:39:05 »
Plug is connected if im looking at the right one , only one near the dipstick but the connector is free and flopping about ..should it be secured to something ie a post or plate ?
« Reply #4 on: 25 March 2012, 20:11:02 »
The wire is slightly worn through as it dropped down and was rubbing on the aux belt , think ill be able to get to it if i take the battery off and top hose . Can it be repaired ie cut and spliced together  :-\
« Reply #5 on: 25 March 2012, 21:25:21 »
Yes. Try to maintain the coax structure
« Reply #6 on: 25 March 2012, 21:32:28 »
Will have a go , dont fancy tracing the wire back to replace . Looks like it goes through the timing belt cover .
« Reply #7 on: 25 March 2012, 21:37:57 »
shouldn't do  :-\
« Reply #8 on: 25 March 2012, 21:40:39 »
Maybe around the back then  :-\ im guessing as i cant properly see until i take the battery off and all the pipework  :-\
« Reply #9 on: 25 March 2012, 22:25:55 »
Maybe im looking at the wrong wire .
Where would the position be of the actual sensor for signal circuit 2 ...not the connection .
Is it ok to run the car or not while the light stays on ?
symes
  • oxford
    • R reg 940 volvo
« Reply #10 on: 25 March 2012, 22:38:00 »
the ks is by engine mount/oilfilter on left side(passenger side) as a thought you did all connections at rear of engine did'nt you-dont ask why?? someone here has done that before(me being a numbnuts)
« Reply #11 on: 25 March 2012, 22:42:33 »
Sure as can be but will double check the back ones  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #12 on: 25 March 2012, 22:56:16 »
just slowly check through everything mate its so easy to rush and skip something(we've all done that) :y its also easy to cross plugs on ks and cam sensor-done that too (crossed air temp and solenoid on front ram pipes) :y
« Reply #13 on: 25 March 2012, 23:05:24 »
Will do , the car runs fine though and only just came on after a run so would make sense that it would be the wire thats worn possibly wearing out on the aux belt causing the fault code . Hopefully i can repair that and job done  :y
« Reply #14 on: 26 March 2012, 10:48:37 »
Knock sensor behind the engine mount. Wire comes up around dipstick, and plugs in cabletray in front of oil filler.
