Author Topic: automaticgearbox issue, no first gear  (Read 1283 times)
robfree
  • ireland
    • 2000 omega 2.5TD
« on: 01 April 2012, 20:05:11 »
I have a 2000 omega 2.5td. it has no first gear but will start in third with the snow button on then i can take it off aftter around 30mph and it will go to 4th and also drop to 2nd. Is ther any way of getting it to start in second all the time instead of first?
SJKOO01
Re: automaticgearbox issue, no first gear
« Reply #1 on: 01 April 2012, 22:54:39 »
A couple of things I'd be looking at before I go about changing things ;)
Have you checked the Autobox fluid level, the gear selector is sitting in the correct position, and are you able to get to anywhere where you can have a code reader give you any codes? :y
Some links that maybe of some help to get you started ;)
http://www.omegaowners.com/forum/index.php?topic=90508.0
http://www.omegaowners.com/forum/index.php?topic=90664.0
http://www.omegaowners.com/forum/index.php?topic=90673.0
sassanach
  • trowbridge
« Reply #2 on: 02 April 2012, 12:54:38 »
do you have reverse?
Omegatoy
  • UK
« Reply #3 on: 02 April 2012, 19:52:10 »
try selecting low on the selector lever, sounds like dirty switch to me,(selector switch on side of gearbox)
