Author Topic: Today I mostly learnt...  (Read 10378 times)
« on: 01 April 2012, 23:00:15 »
... that flourescent strip lights must have an earth to work.  ... I think?
Either that or there is something very weird going on in my garage electrics.
Re: Today I mostly learnt...
« Reply #1 on: 01 April 2012, 23:03:40 »
No appliance "needs" an earth to work. It may need an earth to be safe, but needing one to work implies there is current flowing through the earth conductor, which shouldn't ever happen.
If you can elaborate on what's going on maybe we can figure it out... ;)
tgm147
  • Wirral
    • '02 2.2 Omega CD
« Reply #2 on: 01 April 2012, 23:04:40 »
I think you should get that checked!
« Reply #3 on: 01 April 2012, 23:07:00 »
Indeed... Not good  :o
I thought your place had RCD trips though, which I thought detected Earth leakage :-\
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #4 on: 01 April 2012, 23:10:42 »
If you have a neon screwdriver, carefully pull the cover off the consumer unit and touch the earth busbar and see if it lights up
« Reply #5 on: 01 April 2012, 23:14:26 »
Not a good idea... He's scared of electrickery ::)
« Reply #6 on: 01 April 2012, 23:16:12 »
What was that you were saying about being bad at electrics, Chris?  :o
hotel21
  • The Kingdom of Fife
« Reply #7 on: 01 April 2012, 23:20:37 »
Today i mostly learned that my dad was right.
Do not mix the decanting of fuels with the potential of a naked flame or ignition source.
Just wish the cretins at Total in the North Sea got the same message. Before the wind changed......
BANG!
Nickbat
« Reply #8 on: 01 April 2012, 23:34:26 »
BANG!
Wow. :o
I wish I was as knowledgeable as you about gas flares. ;)
hotel21
« Reply #9 on: 01 April 2012, 23:37:14 »
BANG!
Wow. :o
Not at all.
To have a massive inflammable gas cloud floating about in the proximity of a random forgotten flare flame that, miraculousely, has now extinguished.
Wow.....
« Reply #10 on: 01 April 2012, 23:45:01 »
Explaining may take some time, and I need to understand it myself first. But...
Inherited garage electrics from previous owner. Bit of a diy chap. There is a single plug socket for power in the garage. Off the side of that is a spur(?) wired into the side if the plug socket for lights on a switch as pic below.
The row of power sockets has another wire exiting up as you can see. That leads to two other similar 4 gang sockets in the garage. Plugged into one of these is light with a pull cord by the door. It's alway on as it's plugged into power from the 4 gang socket.
 Where as the rest of the lights are on the switch next to the plug socket in the pic.
At some point long ago, the light on the pull cord failed iirc. I replaced it with a strip light. This was one of two I had that where discarded at work. They both had plugs on. They both work in a plug socket. BUT with plug removed and wired into the electrics to replace the pull cord light it refused to work. And there is stayed for years until today.
In a very rare fit if energy I got facked off with the state of the garage and tidyed up , put shelves back after the boiler was re sited in the garage etc.
 Then... That poxy light....
I unscrewed the pull cord switch cover. Loose brown wire. Unplugged from the 4 gang. Re did the wire. Nfg.
Checked the ceiling rose, unscrewed to reveal a choc box, checked connections no problem. Still nfg.
Unplugged. Meter out. Beeps from the live pin on the plug to the light wire going in. Fine. Nothing coming back from the light on the blue wire.
Plug back in. Diagnostic screw driver shows red light on the live. Not the fuse in the plug.
Swapped the working light onto the same blue brown wire still nfg.
Can't find the fault....
Notice that the strip light has about 2 meters excess cable. Rip the old blue brown flex with no earth out. Run the light cable with earth to the 4 gang socket. It works.
Unplug, run the cable over the ceiling, wire the pull cord switch into the live brown exactly as before. Still works. Fine job done.
Only difference is the new cable as already on the light has an earth. Old cable didn't, and all the old cable bells out for continuity.
It all works fine now.... But Wtf?
« Last Edit: 01 April 2012, 23:54:48 by chrisgixer »
« Reply #11 on: 01 April 2012, 23:55:40 »
Should add I checked loads of stuff, plug connections, socket for power. Etc etc...
« Reply #12 on: 02 April 2012, 00:06:13 »
I really don't like the look of that lot. Best we tidy it up sometime, TBH, Chris. :y
« Reply #13 on: 02 April 2012, 00:22:44 »
In what way? :-\
I should mention, all the sockets are in use. 12 plugs and 4 strip lights run from that one power socket bottom right in the pic.
Although all 3  4 gang sockets running from it have fuses and trips. Plus there's the fuses in each plug as well.
« Reply #14 on: 02 April 2012, 00:24:09 »
Couldn't agree more - its an accident waiting to happen  :o
Pages: [1] 2 3 4  All   Go Up
