Author Topic: Sunroof with a mind of its own  (Read 1960 times)
Dinger
« on: 04 April 2012, 10:30:06 »
Morning all,
My 1996 2.5V6 CD has a electric sunroof which opens and closes all on its own at completely random times,  in all weathers too!
I have tried the reset procedure numerous times but it does not always remember it. I am assuming the black control box alongside the window motor is showing its age, probably got senile dementure I guess. I could replace the box but you lads may have a cheaper solution.  Any thoughts?
Re: Sunroof with a mind of its own
« Reply #1 on: 04 April 2012, 10:32:49 »
Try this, if not, replacement control box needed
http://www.omegaowners.com/forum/index.php?topic=90674.0
Dinger
« Reply #2 on: 04 April 2012, 10:41:07 »
Thanks Rob, I will give that a try later.
Perplexer
« Reply #3 on: 23 April 2012, 01:21:55 »
If that doesn't work, try checking this thread:
http://www.omegaowners.com/forum/index.php?topic=101646.0
hotrod222278
  • southampton
  • Omega MV6 (now dented)
« Reply #4 on: 25 April 2012, 21:05:51 »
Had the same problem, take the switch out and clean with contact cleaner, works well :y
