Author Topic: possible oil pump failure  (Read 2714 times)
downsmen
  • Kent
    • 2.5 V6 Elite Estate
« on: 15 April 2012, 18:55:30 »
high just had to get the car towed home last night :'( it is running really rattly and tappy, the AA man thinks that the oil pump has gone, and he also thinks that i had put to much oil in when i topped it up. would this cause many problems?
what do i need to do next?
many thanks
kcl
  • Finland
    • Volvo V60 D4 -14
Re: possible oil pump failure
« Reply #1 on: 15 April 2012, 19:08:22 »
Is the oil light on? If not I'd say it is not the oil pump. And putting too much oil in... well... you'd have to put several decilitres/ a litre too much to make any harm. Read the codes, something might come up...
downsmen
  • Kent
« Reply #2 on: 15 April 2012, 19:12:14 »
the oil light is on :'(
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #3 on: 15 April 2012, 19:17:11 »
Oh well, that changes the situation... Seems that AA-man is right. Sump off-job I think.
« Reply #4 on: 15 April 2012, 19:21:36 »
I would check the oil pick up in the sump
downsmen
  • Kent
« Reply #5 on: 15 April 2012, 19:30:18 »
is it a hard job? what am i looking for when i get the sump off?
I have access to a pit so i can work easily underneath.
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #6 on: 15 April 2012, 19:31:51 »
What engine? On a V6 it should be only to open all the screws  :-\
downsmen
  • Kent
« Reply #7 on: 15 April 2012, 19:42:27 »
what am i looking for whe i have got the cover off? :y
« Reply #8 on: 15 April 2012, 19:45:07 »
Sump off (loads of M6 bolts) and you`ll see this
downsmen
  • Kent
« Reply #9 on: 15 April 2012, 19:48:25 »
okay great  :y thanks for that. is it possible that the pick up is blocked with gung and with a good clean the engine will be as good as new, or is terminal :'(
« Reply #10 on: 15 April 2012, 19:53:09 »
Can only tell once sump is removed. If strainer is totally clogged would certainly account for the "rattly/tapping" noise
RobseyMV6
  • west sussex
« Reply #11 on: 15 April 2012, 20:12:18 »
What engine is that? might be lucky  :)
downsmen
  • Kent
« Reply #12 on: 15 April 2012, 20:14:12 »
2.5 V6
RobseyMV6
  • west sussex
« Reply #13 on: 15 April 2012, 20:25:56 »
2.5 V6
See how you get on with oil pump, other then that you have a pm inbox from me.
