Pages: [1] 2 3  All   Go Down
Author Topic: Cruise control not working!  (Read 6588 times)
HockeyDave55
  • Milton Keynes
    • 2000my 3.0 police special
« on: 17 April 2012, 17:45:00 »
Hi helpful gurus of all things....  ;D
Ok, I fitted the cruise control and nothing is happening!
Should I get a light on the dash?
I have fitted both switches and I can't see that I've done anything wrong???
Any ideas???
serek
  • huntingdon
    • 3.2 mv6
Re: Cruise control not working!
« Reply #1 on: 17 April 2012, 17:56:40 »
what year of car??
if is DBW need tech2 to active
HockeyDave55
  • Milton Keynes
« Reply #2 on: 17 April 2012, 18:03:26 »
No, it's a 2000, 3.0 with a cable!!!! Man, that cable caused me problems!
« Reply #3 on: 17 April 2012, 18:03:41 »
Going by throttle cable issues he had, guess its a 3.0
No light on dash, you get the full kit from here?
HockeyDave55
  • Milton Keynes
« Reply #4 on: 17 April 2012, 18:08:37 »
Tunnie's right!
No, I got it from Omega Spares on the Bay!
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5 on: 17 April 2012, 18:24:36 »
Sorry, just to confirm -
Stalk fitted / connected?
Module fitted / connected?
Brake and clutch switches fitted?
HockeyDave55
  • Milton Keynes
« Reply #6 on: 17 April 2012, 18:30:27 »
Yes, yes, yes and yes...
« Reply #7 on: 17 April 2012, 18:31:07 »
Brake switch fitted correctly. ??? New or S/H. ??? If the latter I`d suspect the switch
HockeyDave55
  • Milton Keynes
« Reply #8 on: 17 April 2012, 18:33:58 »
I did get a S/h brake switch but the car already had one fitted... I could put it on.????
Is there a way to test the switches???
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #9 on: 17 April 2012, 18:41:09 »
When you say there was already a brake switch present, does that mean you didn't fit the cruise switch you'd bought? The original may not have been for cruise?
« Reply #10 on: 17 April 2012, 18:44:11 »
Odds-on you had a 2-pin switch fitted. When fitted and connected it looks the same as a 4-pin (which you need) ;)
« Reply #11 on: 17 April 2012, 19:37:09 »
As RobG says, you need the 4 pin (two pairs of contacts inside) for your cruise. It'll only take you a couple of minutes to swap over switches.  :y
HockeyDave55
  • Milton Keynes
« Reply #12 on: 17 April 2012, 19:52:27 »
Ok, I could be wrong but the cruise switch is the one with the big lump on it?
HockeyDave55
  • Milton Keynes
« Reply #13 on: 17 April 2012, 19:59:23 »
I'll check the brake switch tomorrow at work....
« Reply #14 on: 17 April 2012, 20:42:26 »
2-pin & 4-pin look the same externally when fitted ;)
Pages: [1] 2 3  All   Go Up
