Author Topic: Ahhh bugger, new exhaust time  (Read 2733 times)
« on: 04 April 2008, 11:35:21 »
Drove past my parked car just......
Whats that haning out the exhaust?    Grey nylony stringy stuff
Guess thats the exhaust knackered then  >:(
How long to total failure from this point?
Re: Ahhh bugger, new exhaust time
« Reply #1 on: 04 April 2008, 11:36:38 »
Not sure how long it will last, but I'd say it will start to restrict flow.
Is it just backbox that needs doing, or centres as well?
smoothomega
  • Perth, Western Australia
  • 2002 2.2DTI CDX,
« Reply #2 on: 04 April 2008, 11:37:16 »
Fishnet stockings  :o ;D ::)
« Reply #3 on: 04 April 2008, 11:37:57 »
No idea to be honest....but I know a man who knows the underside of my car quite well ;)
Admin
« Reply #4 on: 04 April 2008, 11:57:51 »
I suspect Mark will recommend you have the centre sections replaced too. Especially as he will end up doing it! ;)
The Administrator.
« Reply #5 on: 04 April 2008, 11:59:37 »
I don't know what you mean  ::)
Tbh I was thinking to do most of it, its done then.
« Reply #6 on: 04 April 2008, 12:05:28 »
Its not a hard job tbh, though a second pair of hands helps to support stuff I find.  Biggest issue is unbolting the centres from cat section - they can seize a bit.  Get replacement bolts for all of it, and check if you need new rubber hangers, as makes sense to replace missing or badly worn ones at same time.
« Reply #7 on: 04 April 2008, 12:07:32 »
Got hangers already...for some reason there was a set in one of the cubby holes when I bought it!
Read its not too bad a job
« Last Edit: 04 April 2008, 12:07:47 by jimbob »
« Reply #8 on: 04 April 2008, 12:11:47 »
Hmmmmm.....think we might need some heat and some rust flash, from memory those bolts loked a little bit rusty!
« Reply #9 on: 04 April 2008, 12:14:55 »
LOL, a bit of insider knowledge coming out ;D
Jimbob - let M_DTM do it ;D
« Reply #10 on: 04 April 2008, 12:28:04 »
Fancy a weekend away then Mark?
« Reply #11 on: 04 April 2008, 12:29:08 »
Better get the clucking one ( ::) ::) ) onto it then......
« Last Edit: 04 April 2008, 12:29:27 by Mark »
« Reply #12 on: 04 April 2008, 12:30:10 »
She just yelled you bastard ;)
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
« Reply #13 on: 04 April 2008, 13:09:01 »
I had to burn mine out and put nuts and bolts in. I ground them down and tried to drill them but just blunted a load of drills!
best wishes
Simon.
