Replacing brake pad advice and which breaker bar
Started by SMD, 01 May 2012, 18:21:12
The Red Baron
yep, copper grease.
you could no doubt pick them both up from hafrauds.
BiodieselOmega
Can recomend the halfrauds breaker bar...mine has had some abuse.....sorry spirited use and survived very well.
Think of 4ft tube on bar with large sparky swinging on it to get Land rover hub nuts undone!
Free waste veg oil collections....nationwide service by local collectors....never sold for profit....always used as road fuel.
Webby the Bear
To add....
Worth reading my thread about it in addition to the guide.... all of my questions got answered by the wonderful folk on here  :y
RIP Paul Lovejoy
SMD
I looked at the Halfrauds breaker but its out of budget.
Steve I read your thread last night, so my question is can I use this on the caliper slider pins?
Webby the Bear
What is it mate? I can't see pics at work for some reason :(
RIP Paul Lovejoy
Personally, I never use "spray" grease ... several reasons...
It goes everywhere
It is very "runny" to allow it to spray
You can't just put a "blob" on as the carrier gas spreads it
Impossible to use in a grease gun (yes, I still have one and use it occasionally !!)
IMHO it is far better to by a small "tub" of grease and apply it either with a small paint brush or your fingers.
Just my thoughts .. nowt else .. :)
Webby the Bear
Quote from: Entwood on 03 May 2012, 15:08:04
It goes everywhere
+1  :y
Halfrauds sell two types. one's castrol and the one i have is another make, cant remember the name.
you dont want the spray as you need to keep it away from the pad material and just lubricate the places where the pad will move on the calliper mount :)
RIP Paul Lovejoy
Webby the Bear
.... ps as for your original question, also use the stuff out the tub for the slide pins... you want to ''paint it on'' and make sure they can move freely when you replace them ;)
i found a big build up in the plastic boot they sit in. this comes off. i got the crap out of this too cos it was sticking and just lubricated the pin.
hope that makes sense.
RIP Paul Lovejoy
If the grease is likely to come into contact with any rubber parts then you should use Red Rubber Grease (e.g. slider pins) or (what I may well have used in the past, sshh, don't tell anyone) at a push Castrol LM High Temperature grease which is a Lithium high temperature grease.
Petroleum based grease can or will cause the rubber to swell & split.
For pad/calliper contact areas I use copperslip as although it's not a grease, it's also not likely to melt and run all over your disc..
Webby the Bear
Eric the car guy uses silicone paste on the slide pins and anti-seize paste for the pad lubrication.
i suppose theres loads of different variants as long as it deals with high temperature.
RIP Paul Lovejoy
Silicone paste would work too - the main thing is, as you say, it's high temperature and not petroleum based  :y
Red rubber grease is easier to find over here, though :)
SMD
Thanks for the replies. I bought this about 4 years ago so thought might as well use it if I can. I understand its not the easiest to apply but I thought I might get around it by spraying a load of it in a small container or in the lid and then applying it with my fingers  :D. I read that you shouldnt use copper grease on slider pins hence not wanting to buy copper grease for metal to metal contact points and seperate grease for sliders.
Webby the Bear
Quote from: SMD on 03 May 2012, 15:25:36
Thanks for the replies. I bought this about 4 years ago so thought might as well use it if I can. I understand its not the easiest to apply but I could I may get around it by spraying a load of it in a small container or in the lid. I read that you shouldnt use copper grease on slider pins hence not wanting to buy copper grease for metal to metal contact points and seperate grease for sliders.
sounds good if youve got it already.
like E mentioned though it shouldnt be runny so if it is then i'd pick up a tub. t'was only £3.99 iirc ;)
RIP Paul Lovejoy
