Shocking find on Ralf....
Started by Webby the Bear, 07 May 2012, 19:53:31
Webby, IIRC, cam 1 should have 2 numbers on it, a 1 and a 2. These should be next to the 2 'groves' - one of which is tippexed.
What I'm hoping is that the tippexed one has a '2' next to it, and the untippexed has a '1' next to it. If so its only a tooth or 2 out :y
Hope that clarifies what Marks DTM and JamesV6 was trying to say :y
Quote from: TheBoy on 08 May 2012, 19:22:34
That's exactly what I was getting at.. Thanks TB  :y
Webby the Bear
Thanks chaps.
Ok, here is cam 1 with crank at TDC...
RIP Paul Lovejoy
The Red Baron
Oh break me, yes :o
Is it down on power (one for bigyin54 I guess), that doesn't look good. Really doesn't.  What mongrel did that?
Webby the Bear
Just so we get this absolutely clear as I know I can be retarded...... when I say the crank is at TDC..... that's when the line/notch on the crank is at 6 o'clock, right?
RIP Paul Lovejoy
martin42
depends on am or pm lmao  ;D ;D ;D ;D
Webby the Bear
RIP Paul Lovejoy
Quote from: Webby the Bear on 08 May 2012, 19:44:56
yes
Webby the Bear
Quote from: TheBoy on 08 May 2012, 19:50:07
yes
Then we got problems!!! lol
Is it possible that it could be a tensioner failure that's caused this?
I double checked the other sprockets. they are all roughly spot on using the marks on the casing.
RIP Paul Lovejoy
martin42
Webby you know you wanted to a head gasket,looks like your doing a complete top end rebuild  ;)
Webby the Bear
Quote from: martin42 on 08 May 2012, 19:54:02
Is that cos you're predicting the valves will all be bent?
Then fekking bring it on. Most fun i've had since i bought my first adult magazine!!!!!!
RIP Paul Lovejoy
martin42
omegod
Quote from: Webby the Bear on 08 May 2012, 19:55:14
Spat my coffee at that one ;D
Was it running OK before you took the cambelt cover off?
