Author Topic: 2.2 fault code  (Read 2440 times)
2.2 fault code
« on: 14 May 2012, 12:08:24 »
Just put my Maxiscan code reader on a forum member's 2.2 Omega ..... occasional EML. It came up with P1781 which isn't on the list with the paper clip test, but the reader shows "CAN data bus, ECM actual torque signal - malfunction detected"   ??? ??? ??? ???
What's that mean in English?  :-\ :-\
davethediver
  • Blackburn, Lancs.
Re: 2.2 fault code
« Reply #1 on: 14 May 2012, 12:11:14 »
Gearbox code? Whats the fault the cars got?
P.A. Caron de Beaumarchais
Re: 2.2 fault code
« Reply #2 on: 14 May 2012, 12:14:15 »
id be suspecting cam sensor...they are known for chucking up weird codes. esp relating to gearbox
Re: 2.2 fault code
« Reply #3 on: 14 May 2012, 12:22:07 »
None apparently.  :-\ :-\
I thought this code reader only engine codes .........  ??? ???
Re: 2.2 fault code
« Reply #4 on: 14 May 2012, 12:22:51 »
I'll tell him.  :y
Thanks James.
Re: 2.2 fault code
« Reply #5 on: 14 May 2012, 12:37:37 »
As Jimbob says, Code is non-specific to the 2.2 but does on occasion mask the impending 0340
Re: 2.2 fault code
« Reply #6 on: 14 May 2012, 14:11:03 »
I shall point out all your advise .............  :y :y :y
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
Re: 2.2 fault code
« Reply #7 on: 14 May 2012, 15:35:33 »
P1781 - <Unknown DTC>
along with the 0340 one
i had that 2 month ago   new cam sensor job done
never came back
Re: 2.2 fault code
« Reply #8 on: 14 May 2012, 16:30:20 »
never came back
Thanks  :y :y
gibby
  • braintree
Re: 2.2 fault code
« Reply #9 on: 14 May 2012, 17:32:11 »
Hello sir, my name is Gibby, I've Omega 2.2l Z22XE, 3 weeks ago my omega gave all sorts of problems, and when diagonised on the code reader, it had lots of codes & one of them was PO1781. After changing the camshaft sensor all codes disappeared. So I would suggest to check the camshaft sensor.
Re: 2.2 fault code
« Reply #10 on: 14 May 2012, 18:02:18 »
Thank you!  :y :y :y
