Temp gauge incorrect readings...
Started by Hoggy12, 29 May 2012, 14:51:03
Hoggy12
Hi there,
I have just purchased my first Omega and I am chuffed to bits at the amount of car and gadgets I got for my money.
One of the things that I would like to fix up first is that the temperature display is reading at least 40c above the actual temperature...
Has anyone come across this before or know how this could be resolved at all?
Thanks in advance for your help
Mark
Quote from: Hoggy12 on 29 May 2012, 14:51:03.... the temperature display is reading at least 40c above the actual temperature... ........
Engine temp or ambient?
Engine temp sensor is right at the back of the engine & has a single blue wire on it (cue RobG ::) ). New sensor I would think.
Ambient temps sensor is on te lower edge of the front valence (nearside for preface lift, centre for facelift) and a sensor is only around £6. (Facelift cars seem to suffer from a dodgy connection in the loom to the sensor too ;))
Hoggy12
Thanks for that Andy.
It is indeed the outside temperature display that is not displaying correctly so I will have a look at the sensor as you mentioned.
Cheers   :)
flyer 0712
My 2.2 facelift starts at a high temp but then settles after a few minutes to the correct temp..been like it since i brought it 3  1/2 years ago got use  to it now.. if it needs replacing they are cheap enough.. :y
