FITTING A SUB?
Started by innes, 06 June 2012, 11:40:21
innes
how straight forward is it to install a sub in my 2.2 (2000) saloon. Nothing chav just need a little depth as my current stereo sounds shite! CCR2006. its the basic model in 2.2 cd.
Martian
You'll need a live feed direct from the battery (fused of course), and you'll also want a sub that can accept speaker level input as the CCR2006 doesn't have either a dedicated sub output or a line level output.
Diesel or Nuclear ;D....Sorry ::) ;)
innes
ha ha id go nuclear, proper job :D
GastronomicKleptomaniac
Easier to fit a new headunit - I've got a Pioneer in mine that sounds a hundredfold better than the original CDR wotsit.
innes
just stock swap over or speakers too?
mathewst
Need to replace everything, including the speakers if you want a deacent sound.
Speakers will need adaptors to fit properly
Brikhead
Quote from: Martian on 06 June 2012, 11:54:28...a sub that can accept speaker level input as the CCR2006 doesn't have either a dedicated sub output or a line level output.
I have a converter thingumy that connects to the speaker outputs from the standard factory headunit and lowers to signal so as any amp or sub package can be made to work.
Good point on the fuse, and make sure it's fitted as close to the battery as possible.
Quote from: mathewst on 06 June 2012, 20:50:50
I've always thought standard Vx. speakers didn't sound too bad, especially if driven by a decent headunit...
Dave DND
QuoteI've always thought standard Vx. speakers didn't sound too bad, especially if driven by a decent headunit...
Very bad idea !
Original speakers are rated at around 15 Watts and designed to run with an 8 Watt standard head unit.
Putting an aftermarket head unit is going to kill both them and the aftermarket head very quickly, as most head units these days are in excess of 40W per channel - I`ll leave you to do the maths !!
Radio & Decoding Technician
www.dndservices.co.uk
Brikhead
Quote from: Dave DND on 07 June 2012, 08:42:53
Very bad idea !
LOL! Obviously I'm not an auto audio specialist but I have been driving Vauxhalls for years, most of my cars have had amplifiers and large speakers in the boot and I always use high power Pioneer headunits to drive them.
If you set up the tone controls and volume levels properly, and use a bit of common sense then you are unlikely to blow the standard speakers, I never have and I usually listen to 'bass heavy' music.
GmasterT
Big vauxhalls are badass with a decentCarter hu! 45watts is an absolute peak when stated on a head unit and you'll distort long before then. If they're in good nick the standard speakers come alive on a different hu, just don't go mad :)
