Pages: 1 [2] 3  All   Go Down
Author Topic: Fuel problem - 2.2 petrol - wont start !  (Read 10126 times)
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Fuel problem - 2.2 petrol - wont start !
« Reply #15 on: 14 June 2012, 21:34:17 »
Right, got my "My Naff Code Reader" 2 , read the fault code  :(
P1600 reprogramme or replace ECU
is this an easy fix ?
ie can the "My Naff Code Reader" 2 re-flash the ecu ? or do i have to buy a new/secondhand ecu and fit ?
please can somebody help !
try cleaning the ecu plug with the battery off. also read PM
Solar charger fitted.
If not Broke dont fix it..
mathewst
  • Split, Croatia
    • v40
« Reply #16 on: 14 June 2012, 21:34:38 »
Yet to hear of a knackered ECU
I did hear about knackered ECU,
Actually my old 2.2 mig had suffered an ECU breakdown one year after it was bought new.
It was in late 2000 I think.
I know this cause ECU was replaced under warranty so it seems they can go wrong.
But didn't see any ECU problems on the forum  :-\
rsymes2k
  • Devon
    • 99 Omega 2.5v6 CDX
« Reply #17 on: 14 June 2012, 22:03:48 »
isopropryl alcohol on the ecu plug, maplin do a spray can.
Does sound like fuel system though, it starts with damp start as it's letting fuel into the chambers to ignite.
Can you hear the fuel pump priming on 2nd position on key turn?
Start from the petrol tank and work your way forwards.
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
« Reply #18 on: 14 June 2012, 22:38:58 »
So you are saying the techII would possibly give a different result ?
to put you in the picture the clock/date is reading 1.1.1997and 00.00 every time the ignition goes on and doesn't change with ignition on.
Is it a possibility the ecu has fried ? the car did come to a grinding halt !
freecall666
« Reply #19 on: 14 June 2012, 23:08:04 »
thats nothing to do with engine. thats just a time etc display.
markrnorton
  • Essex
« Reply #20 on: 15 June 2012, 08:05:13 »
i thought fuel to start with, fuel pump does not prime in position2, i changed the relay, fuse and even the fuel pump for spares i had, still nothing.
Not sure if its relevant, but i had drove constant for 6 hours in the pouring rain, any chance the wet weather could have got in and scuppered the systems ?
« Reply #21 on: 15 June 2012, 08:21:44 »
Mark, clear the codes and then see what comes back ;)
Where in Essex are you? I might be able to pop down and have a look for you next week (if you can be around during the week) if that will help?
markrnorton
  • Essex
« Reply #22 on: 15 June 2012, 08:49:28 »
Thanks, i am close to Lakeside, Thurrock.
I will have a go at cleaning the ecu plug/terminals later, if this doesnt work, i'll clear codes and re-test. the reader does see the ecu info data on the first screen. not sure if that is significant
« Reply #23 on: 15 June 2012, 08:57:26 »
Hmm, a bit further into Essex than I've got to go but we'll see what happens ;)
If the ECU data is coming up then I find it unlikely to be a faulty ECU ;)
Are any of the dash lights flashing when you crank it?
markrnorton
  • Essex
« Reply #24 on: 15 June 2012, 08:58:38 »
when cranked the engine check light and car/spanner light are on
« Reply #25 on: 15 June 2012, 09:00:38 »
Get a decent code reader on it, ECU's don't just fail or suddenly need their plugs cleaning. More than likely its cam/crank sensor issue
« Reply #26 on: 15 June 2012, 09:01:55 »
But neither are flashing?
« Reply #27 on: 15 June 2012, 09:03:28 »
My thoughts too... Possibly both as it won't start at all but it needs confirming ;) I thought it should still "prime" the fuel system though even if they were faulty so not 100% certain it's not a fuel issue.
markrnorton
  • Essex
« Reply #28 on: 15 June 2012, 09:03:43 »
correct, neither flashing, just on
markrnorton
  • Essex
« Reply #29 on: 15 June 2012, 09:06:37 »
i dont think it is a fuel supply issue, i have changed out the pump/relay/fuse. should it prime even with sensor failure ?
i am used to BMW's, not used to Vauxhalls. its weird.
why would the trip/clock zero as well ?
could water ingress cause an issue somewhere ?
« Last Edit: 15 June 2012, 09:08:19 by markrnorton »
Pages: 1 [2] 3  All   Go Up
