Pages: 1 2 [3]  All   Go Down
Author Topic: Fuel problem - 2.2 petrol - wont start !  (Read 10179 times)
Re: Fuel problem - 2.2 petrol - wont start !
« Reply #30 on: 15 June 2012, 09:11:34 »
Still going around in circles here, you can link it to anything you want until cows come home. But until you get a proper code diagnosis your pishing in the wind!
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
« Reply #31 on: 15 June 2012, 09:50:31 »
yes, you are right !!
« Reply #32 on: 15 June 2012, 10:57:17 »
i dont think it is a fuel supply issue, i have changed out the pump/relay/fuse. should it prime even with sensor failure ?
i am used to BMW's, not used to Vauxhalls. its weird.
why would the trip/clock zero as well ?
could water ingress cause an issue somewhere ?
Flat battery or dodgy connection. Have you checked all the fuses?
Other than that, as already said, you need to get the codes read properly :y
markrnorton
  • Essex
« Reply #33 on: 22 June 2012, 08:14:32 »
Is there anybody out there in OOF land that can help read the codes on my car please with a tech 2, I'm in Essex and would be grateful
thanks
« Reply #34 on: 26 June 2012, 22:38:49 »
Right... Been to look at this today and the only code was to replace ECU ::)
Live data shows a cranking RPM and fuel pump activating. Confirmed fuel at the injection rail. Nothing looks untoward on live data when cranking.
I'm thinking that cam sensor is a likely culprit, although no code :-\ knowing that these are the weak link in the 4 pot engines. Mark agreed with me that it seems most likely so has ordered one as a starting point.
Hopefully an update to follow...
Oh, and thanks for the tea :y
« Reply #35 on: 26 June 2012, 23:09:34 »
 It's about the only sensor to fail, think it would even start with crank sensor disconnected. When genuine sensor started to go, would cause hot starting issues. (lots of cranking) - maybe when they fail completely it's cold starting  :-\
markrnorton
  • Essex
« Reply #36 on: 27 June 2012, 08:32:00 »
Thanks for taking a look Paul.
I'll fit the crank sensor saturday and report back, hopefully its just that.
« Reply #37 on: 27 June 2012, 13:47:18 »
Was really expecting to see a code but it just wasn't there :-\
As I said yesterday, I had to collect something from South Benfleet anyway so no hardship to pop over :y
markrnorton
  • Essex
« Reply #38 on: 30 June 2012, 10:44:21 »
Update on this thread !
Still not working after a camshaft sensor replacement
also on cranking now, its not showing a cranking rpm (whereas it did the other day when Paul had a look)
with fault copde cleared again its still reports back original diagnostic 'ecu re-programme or replace'
Is it likely the crankshaft sensor is the fault ?
any ideas ??
« Reply #39 on: 30 June 2012, 12:38:33 »
any ideas ??
Important thing to note on this is that it doesn't appear immediately, only after a few hours minimum.
It's got me a bit stumped TBH, although I'm not very good with the 4 pots :-[
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #40 on: 01 July 2012, 07:49:23 »
any ideas ??
Was the cam sensor bought from a Vauxhall dealer, or from somewhere else?
I like red cars
markrnorton
  • Essex
« Reply #41 on: 01 July 2012, 08:02:26 »
Genuine vauxhall Sensor from a dealer
markrnorton
  • Essex
« Reply #42 on: 08 July 2012, 18:04:54 »
Just to update this thread
spent a few hours changing the crank sensor, what a nasty job (what madman at Vauxhall put it there)
anyhow car still will not start, i have to go to the ecu now, take it out and apart see whats what
markrnorton
  • Essex
« Reply #43 on: 17 July 2012, 19:29:33 »
Final update
Bought a complete ECU set from Twiglet on here, fitted it tonite , and started first time !
wooo
its rolling again
So , there we are , the "My Naff Code Reader" diagnostic was correct, replace ecu.
the old one must have been toasted
« Reply #44 on: 17 July 2012, 20:31:54 »
Good to hear you got a Result at last Mark  :y
Pages: 1 2 [3]  All   Go Up
