Pages: [1] 2 3  All   Go Down
Author Topic: Fuel problem - 2.2 petrol - wont start !  (Read 10149 times)
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
« on: 08 June 2012, 13:52:00 »
Well, it happened yesterday on the way back from Devon in the pouring rain ! Bloody car stopped !
AA got me home but problem is still there.
Car will fire with damp start sprayed down the inlet, but i have changed the fuel pump relay, checked the injection relay and fuse and this morning swapped out the fuel pump itself. still the car wont start. just the spanner symbol and engine check come up as its spinning over
is there a pressure sensor somewhere or am i missing something ?
BYW the AA man couldnt read any fault codes ? (but he wasnt sure his reader was working either)
Can anybody help ?
please
« Last Edit: 08 June 2012, 13:56:08 by markrnorton »
freecall666
  • looking over your shoulder
    • 2.0l sweat tank on wheels
Re: Fuel problem - 2.2 petrol
« Reply #1 on: 08 June 2012, 13:55:04 »
there is a pressure regulator, round disc next to the intake, has an thin black pipe on it check that its working.
also has the fuel filter been changed?
Solar charger fitted.
If not Broke dont fix it..
markrnorton
  • Essex
Re: Fuel problem - 2.2 petrol - wont start !
« Reply #2 on: 08 June 2012, 13:56:48 »
is that an easy check ? sorry how ?
not sure about the fuel filter, would that stop it dead ?
freecall666
« Reply #3 on: 08 June 2012, 13:59:56 »
if the filter collatses it will stop fuel, test the presure regulator take pipe off at other end and suck on it should hear it moving in and out
markrnorton
  • Essex
« Reply #4 on: 08 June 2012, 14:02:02 »
thanks
i will go and check
markrnorton
  • Essex
« Reply #5 on: 08 June 2012, 14:17:53 »
well i pulled the pipe off the FPR and there is no movement on the diaphram when sucked or blown !
do i take it this would be sufficient to stop it and throw up those dash lights ?
ps where is the fuel filter ? underneath ?
freecall666
« Reply #6 on: 08 June 2012, 14:23:34 »
should hear it move if no moving then the fuel is stopped, filter is just in front of the fuel tank underneth., would change the regulater for a new one or one that works,
p.s remember when you take the regulator off there will be fuel pressuer so keep a rag on top of it and dont smoke.
« Last Edit: 08 June 2012, 14:27:10 by freecall666 »
« Reply #7 on: 08 June 2012, 14:32:44 »
Fact AA could not read codes, no surprise there!
Fact spanner light is on, suggests there is a code there to be read  ;)
My thoughts are cam sensor, it usually causes hot starting issues.
markrnorton
  • Essex
« Reply #8 on: 08 June 2012, 14:47:12 »
i might try the FPR first as its cheap and easy. thing is, the car stopped as i was driving along and now from cold this morning still nothing.
also, it did cough into life with the damp start down the inlet, suggesting it was sparking
i assume the cam sensor on the 2.2 is at the front under the belt covers ?
« Reply #9 on: 08 June 2012, 14:55:53 »
I would stop using that personally, get codes read first.
Yes pop off aux belt, and timing belt cover, its between the cams, locked in place with a small bolt.
But before you go changing anything, read codes  ;)
markrnorton
  • Essex
« Reply #10 on: 08 June 2012, 15:55:51 »
good advice
just ordered a fault code reader. will investigate further
thanks
markrnorton
  • Essex
« Reply #11 on: 14 June 2012, 19:23:15 »
Right, got my "My Naff Code Reader" 2 , read the fault code  :(
P1600 reprogramme or replace ECU
is this an easy fix ?
ie can the "My Naff Code Reader" 2 re-flash the ecu ? or do i have to buy a new/secondhand ecu and fit ?
please can somebody help !
« Reply #12 on: 14 June 2012, 20:19:33 »
Shite
'dangle berries'
No chance
Get a decent OBDII reader or get it on a TechII
markrnorton
  • Essex
« Reply #13 on: 14 June 2012, 21:03:43 »
what difference will a different code reader make ? it will still read the same fault surely ?
what does a techII do different ?
do the ecu's fail ?
« Reply #14 on: 14 June 2012, 21:06:18 »
Will give you the actual code, not the crap "My Naff Code Reader" has given.
TechII does everything, that`s why they`re in excess of £2,500.00.
Yet to hear of a knackered ECU
Pages: [1] 2 3  All   Go Up
