Author Topic: Walnut facia removal ?  (Read 3055 times)
« on: 10 June 2012, 10:18:49 »
Hi omega people , cant see any guide for facia removal on the P/F only F/L ? I want to remove all the walnut looking panel and ashtray inc the bit under the handbrake . Had a quick look and opened the ashtray and cant see any screws  :-\ some kind of hudini fitment  :(
  • Auckland
    • Mazda MPV
Re: Walnut facia removal ?
« Reply #2 on: 10 June 2012, 10:57:46 »
On my old CD (poverty spec) pre-facelift the fixing screws were revealed by pulling all the knobs off. ;D
The ashtray is held in by a single screw. Hold down the spring loaded flap and use a long Pozidrive screwdriver to reach in to undo it. I think the trim clips onto the front of the ashtray but I wouldn't try to remove it with the ashtray in place because I don't think the mechanism is robust enough to cope.
I never tried to remove the tray under the handbrake. On my automatic facelift the gear lever surround is held in by two spring clips at the rear. With that popped out the screws holding the fake wood are easy to remove. My guess is that the pre-facelift was the same :-\
« Reply #3 on: 10 June 2012, 11:07:45 »
I have managed to remove the tray under the handbrake without hack sawing off the gear lever "auto"  :) I think that was the easy bit  ::) Ill have a look at the guide rob posted  :y
« Reply #4 on: 10 June 2012, 13:17:22 »
Arrrgh ! I got the radio out and all the buttons , the bottom of the surround is loose but it wont budge ...seems like something is holding it in the middle  >:( :(
Help help !
« Reply #5 on: 10 June 2012, 13:24:44 »
So reading back there is a release bar ? I cant get to it as i im stumped how the radio cage is fixed in ?
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #6 on: 10 June 2012, 13:28:09 »
Is it the one with the climate control like this?
If so you need to reach up behind through the stereo aperture and feel for a flat aluminium bar about 6-7 inches long. This needs to be pulled downwards. It's quite hard to get it moving - I used a screwdriver to *carefully* lever it downwards at one end them worked across to the other end.
Once the bar is moved down the facia virtually falls out.
Sometimes the cage has a small nut or bolt in the back - you should be able to see it if you look into the aperture.
« Reply #7 on: 10 June 2012, 13:33:36 »
Yes thats the one murph , ill have a better look after dinner but couldnt see anything holding the radio cage ... losing patience with it so having a break  ;) took me 2 hrs to get the radio out using nails as i didnt have the radio removal pins  ::) :y
Murph
  • Dartford, Kent
    • 2.5 Estate
« Reply #8 on: 10 June 2012, 13:37:47 »
Often the best way to remove the cage is to pinch the top and bottom edges in the middle so that it bends away from the surround.  It's easy to bend it back to straight when you refit it.
« Reply #9 on: 10 June 2012, 15:53:31 »
Arh what a mess  :(
Got the bits i needed  :y
You need to be double jointed to get to that releasing bar  :o
« Reply #10 on: 10 June 2012, 16:11:45 »
check the sampling fan
What does that do then ?
  • Auckland
    • Mazda MPV
« Reply #11 on: 10 June 2012, 17:07:13 »
Sucks (samples) air from the cabin so the climate control temperature sensor knows how hot/cold you are.
« Reply #12 on: 10 June 2012, 18:52:44 »
Arr thats ok then , climates been ripped out  ;)
Now do i decide to put the sat nav screen in or not  ::) It dont get used anyway ...time to check the bulbs on the panel . I can only see 3 bulbs , one seems to be hidden behind one of the centre ones and the one that i need to replace  :-\
« Last Edit: 10 June 2012, 19:04:52 by eatmydust »
« Reply #13 on: 10 June 2012, 20:05:00 »
You mean the air/con has been removed ....  :-\ You car's interior still needs a sampling fan otherwise it'll give you all hot or all cold air and won't be able to maintain the temp selected.  ;)
« Reply #14 on: 10 June 2012, 21:55:09 »
Oh i see , i think the unit has to be taken apart and looking at it i cant see how..was working fine before anyhow  :)
Page created in 0.111 seconds with 16 queries.
