bog down
Started by pauls, 18 June 2012, 11:52:21
pauls
I have a strange one now, sometimes while driving when I slow down and then hit the fast peddle the car hesitates like I have flooded it, it then takes off ok. Also when slowing down to a stop for lights etc the revs sometimes drop to about 500 for a few seconds then picks it selve backup to 600, is this correct or do I need to clean or replace something.
cheers Paul.
noel
may need throttle body cleaning  :y
bigboykarl
this reminded me of
O'Driscoll was sinking in a bog, near Killarney in County Kerry, and seemed a goner when Big Dermot McCann wandered by...
'Help!' O'Driscoll shouted, 'Oi'm sinkin'!'
'Don't worry,' assured Dermot. 'Next to the Strong Muldoon, Oi'm the strongest man in Erin, and Oi'll pull ye right out o' there.'
Dermot leaned out and grabbed O'Driscoll's hand and pulled and pulled to no avail. After two more unsuccessful attempts, Dermot said to O'Driscoll, 'Shure, an' Oi can't do it. The Strong Muldoon could do it alone, mebbe, but Oi'll have to get some help.'
As Dermot was leaving, O'Driscoll called 'Dermot, Dermot! D'ye think it will help if Oi pull me feet out of the stirrups?'
one of the sensors :-X
SIR Philbutt
Is it an auto - mine will do that sometimes when i dont give it chance to sort itself out
pauls
SIR Philbutt
#6
Quote from: pauls on 19 June 2012, 21:09:55
Yes its an auto
IMO the hesitating is a "feature" of the auto box as said previously. The revs dropping I cannot recall mine doing.d
Depending on the mileage (normally around 80K) most would suggest a filter and fluid change (guide here http://www.omegaowners.com/forum/index.php?topic=90664.0).
But there does not appear to be much wrong with it to me. I am sure I will be corrected by somebody more experience on here if i'm wrong  ::)
edit: I now "select" a lower gear if I know I am going to want to boot it when approaching junctions I normally go through so as to avoid it hesitating
HTH
Phil
Speak to SMD about this symptom.
He had exactly this, until I corrected his cam timing by several degrees...  ;D :y
SIR Philbutt
Quote from: JamesV6CDX on 03 July 2012, 00:17:13
But wouldn't there be other symptoms if the cam timing was out.  :-\
If you'd said cam sensor then I would have kept quiet  :-X
Quote from: Philbutt on 03 July 2012, 00:38:50
I would have thought so.... :-\ :-\ :-\  Ours is an auto, plant it and it goes.... :y :y
SIR Philbutt
#10
Quote from: Vamps on 03 July 2012, 00:43:12
Ahhh the 2.6.  ::)  ;)
My understanding of the post is that, in the moment between stopping and then not doing, there is that hesitation from the box while it tries to get into 1st gear and then off it goes. Since I read this I have managed to do it a couple of times and realised what the op is concerned about.
I have also noticed the little "blip" of the rev's hunting down and then settling to tickover when coming to a hard stop. Which I have decided is the same sort of thing.
AFAICR my previous 2.2 auto did the same before and after cam belt and then a sensor change  (for other reasons)
I have always accepted this as normal ?
I've not experienced the issue and subsequent improvement myself.
All I know is that
A) SMD's car was experiencing a 'lag' when putting foot to floor.
B) It's timing belt was checked because of concerns with previous fitter
C) Timing was found to be a few degrees out
D) Timing was corrected
E) Lag disappeared
;D
In fairness, it could have been something indirect, EG reseating a loose vacc pipe during cambelt work... but I think it's more than a co-incidence that once corrected, the issue disappeared.
Only throwing ideas into the bag, guys :y
SIR Philbutt
Was the SMD's lag happening every time he put his foot down or like the op (and me) has described
In all other situations when I want mine to go, it goes, and I think well for a 4 pot  ::) on LPG
pauls
Just a follow up, this does not happen all the time and it does seem to happen more when the weather is warm
cheers Paul
P.S. Saying the above I have not noticed it for a while now. Either that or I just get on with now.
A little lag is normal on the inferior DBW engines with autoboxes, if you confuse it by lifting, then asking for power.  Affects 2.6 and 3.2 models.
This doesn't affect the superior non DBW engines.
This lag is miles more noticible with the AC Stag LPG setup, but definately still present on petrol, and proved on multiple cars.
