Pages: [1] 2 3  All   Go Down
Author Topic: Key fob has stopped working  (Read 7608 times)
PAULCDX
« on: 19 June 2012, 16:56:27 »
Hi Guy's
After the car has been sitting on the drive for a month or so she was finally started up and was left running today.. All is fine on that front  :y
Only prob I have now is my one and only key seems to have stopped responding to the car? I can't lock, open or open the boot?
Any ideas?
Thanks in advance  :y
Paul
RobG
    • 16 plate Mokka. Vivaro
Re: Key fob has stopped working
« Reply #1 on: 19 June 2012, 16:57:20 »
Key in position II and press fob
PAULCDX
« Reply #2 on: 19 June 2012, 17:02:05 »
Cheers Rob, I will give that a go  :y
RobG
« Reply #3 on: 19 June 2012, 17:02:52 »
5 minutes to reply, thought you`d have done it by now ;D ;D ;D ;D
PAULCDX
« Reply #4 on: 19 June 2012, 17:05:07 »
Lol,  ;D
Was busy doing something else............. On way out the door now  ;D
Thanks  :y
PAULCDX
« Reply #5 on: 19 June 2012, 17:10:26 »
Nope nothing working?? Just wondering if the battery has gone? May be worth changing and then trying again...........
Strange cos it did work the other day
RobG
« Reply #6 on: 19 June 2012, 17:15:55 »
Possibility
PAULCDX
« Reply #7 on: 19 June 2012, 17:18:55 »
Can't see that little red light on the fob when I press the buttons so I guess changing the battery will be a good start  ;D  ::)
Thought the key may have gone out of sync with the car as it hasn't been used for two months or so........ Had kept the car unlcoked whilst the battery was dead etc..........
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #8 on: 19 June 2012, 17:19:38 »
if the bat has died then it will need a re-sync anyway. as said, key in ignition, doors closed, press & hold button, locks close then re-open. if i remember right.  :y
PAULCDX
« Reply #9 on: 19 June 2012, 17:22:03 »
Cheers Jon,  I do remember it working a few days ago but since then perhaps the battery has died  :o
Will get it changed and then try and re- sync to the car  :y
Thanks  :y
allen25
  • Worcestershire
    • Omega 2.6 V6 2001
« Reply #10 on: 19 June 2012, 17:27:29 »
Tried to reply a moment ago but for some reason the post did not work. I have recently replaced my key fobs. The originals were shot, both batteries and buttons. The new fobs needed recoding to the ECU (computer chip). The dealers like this work! If the ECU still 'remembers' your fob after a battery failure/replacement you may be able to recode it as per one of the previous threads (position 2 and press a remote button) detailed in the owners manual. You can use the key alone in certain models but you need to unlock, re-lock and re-unlock in sequence in a matter of a few seconds to prevent the alarm activating. Annoying for the neighbours a t 7am if you continually get it wrong. I've sorted mine now so come back if you are stuck.
PAULCDX
« Reply #11 on: 19 June 2012, 17:33:52 »
Am I right in thinking if I leave the car unlocked at the mo until I get the battery changed ( cos I need to buy one ) I'm not going to be causing any alarms or powersounder to go off?
Can I still drive the car if I need to? Sorry for the stupid questions  :D  :D  ;D
Once I change the battery, will I just need to re - sync to the car and all should work?
Thanks for all your help  :y
RobG
« Reply #12 on: 19 June 2012, 17:35:14 »
Yes, yes & yes.
You have three yes`s ;D
PAULCDX
« Reply #13 on: 19 June 2012, 17:35:57 »
Thanks, thanks and thanks  ;D  :D
PAULCDX
« Reply #14 on: 19 June 2012, 17:37:17 »
Just wondered cos I've read some frightening stories about alarms and powersounders going off and even damaging the car etc  :o
Pages: [1] 2 3  All   Go Up
