Author Topic: Exhaust  (Read 1954 times)
AndysCD
  • Halifax UK
    • VAUXHALL omega CD
Exhaust
« on: 01 July 2012, 15:03:38 »
Hi guy`s
Downpipe and centre pipe needing replaced, could anyone tell me if i need Genuine for either or whats the best aftermarket ones. 2.0 cd estate. 99
Regards
Andy
Re: Exhaust
« Reply #1 on: 01 July 2012, 16:47:11 »
Why does down pipe need replacing? Do not use pattern parts they sound awful, mid & rear sections you can get from Eternal, its £75 cat back for an exhaust from them.
Re: Exhaust
« Reply #2 on: 01 July 2012, 19:14:21 »
If its because flexi has gone, find somewhere able to weld in a new flexi
AndysCD
  • Halifax UK
    • VAUXHALL omega CD
Re: Exhaust
« Reply #3 on: 02 July 2012, 08:44:52 »
cheers guys
yes as you suggest its prob flexi thats knackered. Is this a part you can buy?
Regards
Andy
Re: Exhaust
« Reply #4 on: 02 July 2012, 09:12:08 »
cheers guys
Regards
Andy
Yes, its available, about £20 from egay iirc. Most fast-fit places won't have the ability to weld it in though. Maybe a local member can, or try a local engineering firm :y
AndysCD
  • Halifax UK
    • VAUXHALL omega CD
Re: Exhaust
« Reply #5 on: 02 July 2012, 09:16:32 »
Thanks, welding not a prob,  i have a Mig welder. Thought maybe it would just require cutting out and the replacement would be a clamp fitting for both ends. Do you know what size i need?
Thanks again
Andy
« Last Edit: 02 July 2012, 09:18:59 by AndysCD »
Re: Exhaust
« Reply #6 on: 02 July 2012, 09:19:10 »
Thanks, welding not a prob. i have facilities. Thought maybe it would just require cutting out and the replacement would be a clamp fitting for both ends.
Thanks again
Andy
The only ones I've seen are weld-in replacements
Re: Exhaust
« Reply #7 on: 02 July 2012, 09:36:17 »
Thanks again
Andy
100mm x 51mm  :y
Re: Exhaust
« Reply #8 on: 02 July 2012, 09:38:16 »
Something like this, although never used this place before:
http://exhaustpartsuk.com/index.php?main_page=product_info&products_id=1307
Make sure its welded as close to original as before, because even if its just a fraction longer it can push the first mid section turn very close to the heat shield and cause a rattle at idle  :y
AndysCD
  • Halifax UK
    • VAUXHALL omega CD
Re: Exhaust
« Reply #9 on: 02 July 2012, 10:04:10 »
Cheers
One ordered, appreciate the tip tunnie
Thanks again.
Andy
