Help required
Started by Bob G, 05 July 2012, 16:17:39
Bob G
anyone in the Gloucester area (tried James but not replying) up for helping me replace front bushes, have read and re read the article but do not feel confident about it.  If only advice thta will be great.  Not available this w/e but free most evenings.
Agemo
The guide is brilliant, easy enough job if you take your time. If you have spare wishbones you can do it in stages. You DO mean Poly bushes?
Bob G
Quote from: Agemo on 05 July 2012, 16:29:23
Yes poly bushes, the only bit I am not 100% is obviously new bolts but the torques setting and how to apply in air or on ground, once thats sussed will be ok
With polys, it matters not if you do it in air or on ground :)
Bob G
Quote from: TheBoy on 05 July 2012, 22:55:06
great thanks any idea on torque setting?
Agemo
As TB says, no need for the wheels to be on the ground, as the Poly bush is allowed to revolve at will.  I presume you are following Razzo's guide? (http://www.omegaowners.com/forum/index.php?topic=90676.0)  :y
Torque settings are :-
"The bolts should be tightened to 120nm, then angle tightened a further 30 degrees, then a further 15 degrees"
All in chrisgixer's guide.  http://www.omegaowners.com/forum/index.php?topic=90658.0 :y
