Author Topic: Wtd Ali rocker covers for V6 Elite  (Read 2993 times)
Father_of_four
« on: 17 July 2012, 11:59:19 »
Hi All
Could anyone help with advice on getting hold of Ali rocker covers for my V6 Elite. I am wanting to cure the gasket leaking problem asap. I have fitted new gaskets recently, and when the MOT was carried out my good friend advised me that i still had leaks, and recommended the Ali covers.
Any advice or contact details to precure a pair of thes ellusive parts would be mos grateful.
Best regards
Craig
Re: Wtd Ali rocker covers for V6 Elite
« Reply #1 on: 17 July 2012, 12:04:29 »
Hi Craig.
I really wouldn't bother with the alloy covers, they can cause more trouble than you have already. You need to fit genuine gaskets and clean the breathers out and the original cam covers should be fine :y
« Reply #2 on: 17 July 2012, 12:05:45 »
As Pete said really....
What gaskets were fitted, if it wasnt genuine, and they werent torqued correctly, then a leak is to be expected :(
Father_of_four
« Reply #3 on: 17 July 2012, 12:17:02 »
Thanks
I bought gaskets from local motor factors, so you recommend genuine gaskets from Vauxhall dealer ?
« Reply #4 on: 17 July 2012, 12:19:21 »
Yep, genuine only. There are two on the forum that say they have fitted pattern part gaskets with success but the majority and its a huge majority have had them fail within weeks or months. Give me a shout if you need some, looks like your not too far away and I get them at a very good price :y
Father_of_four
« Reply #5 on: 17 July 2012, 12:23:52 »
Thanks,
genuine it is then ! I will be pro at changing these soon. How many dubloons are we talking for a pair of the finest ?
vauxhallvauxhall
« Reply #6 on: 17 July 2012, 12:28:30 »
covers off vectra 2.6
« Reply #7 on: 17 July 2012, 12:31:33 »
There are 2 problems with Vectra covers. 1 the oil filler neck is at the rear of the engine and 2, if the breathers block there's a good chance that instead of the cam covers leaking the crank shaft oil seal will let go instead and I know which on i'd rather change ::)
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #8 on: 17 July 2012, 13:09:02 »
Agreed. A good job on the breathers and gaskets, and regular cleaning of the breathers, is all you need :y
« Reply #9 on: 17 July 2012, 13:11:45 »
Don't forget the correct torque! 8Nm :y
« Reply #10 on: 17 July 2012, 13:12:10 »
Which is roughly using your little finger and a cotton bud on the socket :y
Father_of_four
« Reply #11 on: 17 July 2012, 19:16:17 »
that could have beenbolts my problem, I have over tightened the bolts ?????
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
« Reply #12 on: 17 July 2012, 19:34:04 »
another cam cover gasket thread. Where's tunnie and Ralf? Lmao
RIP Paul Lovejoy
martin42
« Reply #13 on: 17 July 2012, 19:41:21 »
I'm not saying nowt so as I don't offend any1 just because I use pattern cam gaskets and they don't leak lmao  :y
« Reply #14 on: 17 July 2012, 20:26:26 »
yet! Pmsl
