Author Topic: Air Con  (Read 5694 times)
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
Air Con
« on: 29 July 2012, 09:55:08 »
Hi all, i have what appears to be a leaking air con pump...I have had it pressure tested, and nitrogen tested which produced no signs of any leaks...However, when it is re-gassed, the front clutch appears to frost up so we believe the pump has had it...Has anyone had to have this changed, and a rough guide on price/difficulty would be of help...Thanks.
Re: Air Con
« Reply #1 on: 29 July 2012, 11:19:48 »
Changed a couple. Bit 'fiddly' but not hard. 2 people make it easier, one underneath trying to get the pipes on and off, another from top undoing the bolt that holds pipes on.
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
Re: Air Con
« Reply #2 on: 29 July 2012, 12:28:12 »
Thanks for the reply, any idea on price?? I am guessing not cheap from VX :(
Re: Air Con
« Reply #3 on: 29 July 2012, 13:08:49 »
tradeclub, about £250 on exchange basis IIRC, for refurbed
Re: Air Con
« Reply #4 on: 29 July 2012, 13:24:27 »
MarksDTM refered me to somewhere else for the compressor for mine ........... can't remember now who though  :-[
Re: Air Con
« Reply #5 on: 29 July 2012, 13:27:33 »
Avoid the dealers whatever happens. Try a used one from a breakers in the parts section or Steve in Heathrow, a member here. ;)
Re: Air Con
« Reply #6 on: 29 July 2012, 13:29:12 »
Although how does the clutch frost up? :-\
Is it engaging and turning as it should?
Re: Air Con
« Reply #7 on: 29 July 2012, 13:34:55 »
........... Try a used one from a breakers in ............
I wouldn't use a 2nd hand compressor, you've no way at all of telling whether the seals in it are any good.  ;)
Re: Air Con
« Reply #8 on: 29 July 2012, 13:40:43 »
Fair comment I suppose. I certainly wouldn't use vx though. Not without crying rape.
How much are seals?
Re: Air Con
« Reply #9 on: 29 July 2012, 14:07:18 »
How much are seals?
I've never tried to strip a compressor ........... there's a GM compressor in my garage if you want to try  ;) but I'm pretty sure you need specifc pullers to strip one down. As said, Mark recommended a supplier & I bought mine from them. It's still working a few years/summers down the line.  :y
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
Re: Air Con
« Reply #10 on: 29 July 2012, 16:33:28 »
Hi, the clutch engages and spins as it should with gas in, but the gas runs out after barely a week...It appears the clutch frosts up on the front, so i am assuming its leaking, and thats why the gas lasts for such a short time.
Re: Air Con
« Reply #11 on: 29 July 2012, 21:37:18 »
How much are seals?
Looks like the op could do with a link Mr P. :)
Re: Air Con
« Reply #12 on: 29 July 2012, 21:53:59 »
How much are seals?
Looks like the op could do with a link Mr B. :)
I refer the learned gentleman to the reply (#4) I gave earlier .......  ::) ::) :y ;D ;D
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
Re: Air Con
« Reply #14 on: 31 July 2012, 20:41:32 »
Hi Andy B, o.k thanks i will take a look.The one you have in the garage may be of interest though??....Appreciate the help :y :y
