Author Topic: 2.2cd auto  (Read 2110 times)
gpenny07931
  • greenock (scotland)
    • omega 2.2cd auto
2.2cd auto
« on: 22 August 2012, 21:00:31 »
Car had just had engine replaced. It now won't change gear when it is in drive? It pulls away in a high gear and stays in it. The gears seem ok when selecting 1-2-3 but won't change in drive? The lights are also flickering on and off at the gearstick? Gearbox oil is fine?
SIR Philbutt
  • Rochdale - Manchester
    • 03 2.2 CDX LPG estate
    • PJB Home Services
Re: 2.2cd auto
« Reply #1 on: 22 August 2012, 21:05:43 »
sounds like the selector
Good guide here on how to clean http://www.omegaowners.com/forum/index.php?topic=90673.0
HTH
Phil
Re: 2.2cd auto
« Reply #2 on: 22 August 2012, 21:06:38 »
Just what I was about to say ......  ;D ;D :y
gpenny07931
    • omega 2.2cd auto
Re: 2.2cd auto
« Reply #3 on: 22 August 2012, 21:20:37 »
I will give that a try. Would this cause the car to stay in one gear? The lights seem asif they dont know what's going on they light up the wrong bulbs on the gearstick and all come on and off at once?
Thanks for your help its much appreciated.
SIR Philbutt
    • PJB Home Services
Re: 2.2cd auto
« Reply #4 on: 22 August 2012, 21:31:28 »
Ha beat you to it  ;) - getting good at this now  ;D
AFAIK selector tells ecu which gear/mode to put box in,  if not sending right info you get wrong operation. if it's still doing it after clean add to thread. Andy might beat me to it next time  ;D ;D
gpenny07931
    • omega 2.2cd auto
Re: 2.2cd auto
« Reply #7 on: 26 August 2012, 21:42:16 »
Took off the selector and cleaned it up with some switch cleaner today. Broke 5 of the 7 bolts holding the unit together! After a bit of drilling and scrubbing I put it back together, stuck it back on the car and its going fine now. Cheers for the advice. Now onto the heater bypass valve then a right good polish. The joys.
