Author Topic: Question for electricians ............  (Read 1259 times)
I_want_an_Omega
« on: 24 August 2012, 20:25:26 »
I want to connect up 3 outside security lights - which will draw a max of 300 watts each. I've got a spare position on my fusebox and a 6amp breaker available.
My question is, can I use 1mm cable to run from the breaker onto the 1st light and then onto 2nd and 3rd
Hopefully I can as I've got the best part of a drum of 1mm cable - fingers crossed.
Thanks - Rob
Re: Question for electricians ............
« Reply #1 on: 24 August 2012, 21:09:44 »
1mm T/E is sufficient depending on cable run. Don`t forget to wire them in parallel
I_want_an_Omega
« Reply #2 on: 24 August 2012, 21:11:14 »
Thanks & noted. It's probably about 15m in total ..........
« Reply #3 on: 24 August 2012, 21:13:19 »
1mm T/E :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #4 on: 24 August 2012, 21:28:44 »
Are these cables being run in a conduit rob ?
Martian
« Reply #5 on: 25 August 2012, 02:32:07 »
Don't forget it will need signing off
I_want_an_Omega
« Reply #6 on: 25 August 2012, 07:47:44 »
Yep
I_want_an_Omega
« Reply #7 on: 25 August 2012, 07:49:36 »
Wasn't planning on that Steve - the entire run is in a roof ..............
Martian
« Reply #8 on: 25 August 2012, 10:22:29 »
A 20 metre run in an enclosed (less than 100mm) space with a current demand of 4 amps (1000W) at 230V will result in a voltage drop of just under 4V, so 1mm˛ T&E will be fine for your application.
Don't forget to provide a suitable means of isolation.
« Reply #9 on: 25 August 2012, 11:43:49 »
I've got a Biro you can use Rob ;D ;D
I_want_an_Omega
« Reply #10 on: 25 August 2012, 12:47:23 »
 ;D
thanks all
