rear wheel bearing being done tomorrow
Started by Jimbob, 10 September 2012, 17:36:03
At a local place, also having my geometry done.
Bearing has gone from a slight noise, to bad in a couple of days, so darent leave it any longer.
£80 which I dont think is bad at all, I am supplying the bearing too.
Be interesting to see how much of a battle they have  ;D
Quote from: Jimbob on 10 September 2012, 17:36:03
Bet they take a tad longer than Mr Sassenach's 1 hr 40 minutes .. which included a  search for tools as well ..  :)
Omegatoy
HELL THAT BEAT ME AND I THOUGH I WAS QUICK!!
2.hr35 but i took the whole arm off and then pressed it out and new one back in and no i didnt wreck the backplate!!
And Jimbob what's with you and your back end?  ;D
serek
Quote from: Entwood on 10 September 2012, 17:39:59
thats about right if  brake disc come off easy :y
Estates often seem trickier for some reason
The last one we did of yours was pretty easy
In comparrison the the first one, hell yes ;D !!!!
Reading all the posts on here though, its nearly always the estates that are problematic for some reason, can there be anything more to it that the larger bearing?
No, its luck.
Having developed 'techniques' I cant see me needing to remove an arm again.
What sort of mileage are these failing at?
Mine have done nearly 235k and are still relatively noise/play free :y How much longer could they last?
