Author Topic: Wet Gearbox selector switch  (Read 1523 times)
« on: 25 September 2012, 14:34:42 »
Weve some localised flooding around here, nothing too deep.....
but enough to cause Big Blue's selector switch to light up like a christmas tree..
Whats the best procedure?
leave it to dry out naturally?
take it off?
should I open it up....and do what?
I may have a spare here already....again, what should be done to refurb?
Re: Wet Gearbox selector switch
« Reply #1 on: 25 September 2012, 16:21:50 »
I would say that opening it up and drying it off would be preferable, if you can spare the time. It might dry out itself and work again, but that will no doubt leave some crud and corrosion inside. Better it's sorted now than it lets you down later when you've forgotten it happened. ;)
« Reply #2 on: 25 September 2012, 16:26:32 »
any grease or anything recommended?
or open, clean with switch / contact cleaner, reseal?
« Reply #3 on: 25 September 2012, 16:32:33 »
Not much required grease wise in there, a bit of vaseline at the most.
I seem to recall changing that one before when Bob had it, there a bit harder to get at/off with the pre-cats present (in fact the precats are a pain for a number of jobs!)
« Reply #4 on: 25 September 2012, 16:36:49 »
That was another Telford job, IIRC.
« Reply #5 on: 25 September 2012, 16:51:51 »
Yes, found mention of Bobs back in 08 or sommat.
Ill wait for everywhere to dry out, then Ill take it off.
Have a spare if needs be.
