Author Topic: maf and ecu  (Read 1339 times)
rinkleyrob
  • Stevenage, herts
maf and ecu
« on: 26 September 2012, 12:37:05 »
Hi The saga of my maf continues, been tested on tech 2 apparantly  no faults found, no wiring fault found between maf & ecu, been suggested it,s ecu. Anybody got any ideas, all set to get rid. 2.2 petrol auto 2001 model 86000 miles.
Re: maf and ecu
« Reply #1 on: 26 September 2012, 13:03:09 »
Have you put on the genuine MAF twiglet offered?
I've seen pattern cats on 2.2, they look and sound shite. I also notice on one recently it had no pre-cat sensor, wonder if thats affecting things  :-\
Re: maf and ecu
« Reply #2 on: 26 September 2012, 15:40:20 »
Was the tech 2 test checking live data or did they simply look for fault codes.
It needs a proper live data analysis with the MAF readings being observed, I would expect the MAF value to either be to high or to low, this would not raise a fault code though
rinkleyrob
  • Stevenage, herts
Re: maf and ecu
« Reply #3 on: 26 September 2012, 19:48:02 »
Don't know about the live readings I wasn't there, just went on what they told me. No I didn't use Twiglets maf as I purchased a genuine seimens.
rinkleyrob
  • Stevenage, herts
Re: maf and ecu
« Reply #4 on: 27 September 2012, 12:25:38 »
Read Tunnies reply to my problem, just been & had a look can only see one sensor on the cat. I had the cat replaced a little while ago & I supplied the mechanic with 2 sensors genuine, he supplied the cat I'm suspecting he has fitted the wrong cat, could this be the case. Ican see one through the engine bay just below the manifold, where should I be looking for the 2nd.
« Last Edit: 27 September 2012, 12:34:14 by rinkleyrob »
rinkleyrob
  • Stevenage, herts
Re: maf and ecu
« Reply #5 on: 02 October 2012, 14:18:06 »
Hi Cleaned throttle body all gunged up, now got slight miss on tickover, fine under power. Have I done something wrong?.
