Author Topic: Frustrating drop links!  (Read 4116 times)
a2reed
  • Battersea London
« on: 29 September 2012, 01:38:55 »
Replacing the drop links and I turn the 18mm nut and it turns and turns ... any idea how I hold the shaft still?
Re: Frustrating drop links!
« Reply #1 on: 29 September 2012, 01:48:15 »
17mm spanner on the flats on theother side of the ARB/Strut :y
If needs be keep turning the 18mm nut until the spanner slips on :y
a2reed
  • Battersea London
« Reply #2 on: 29 September 2012, 01:56:17 »
Good news ....erm guess which is the only spanner size I don't have!!!!!
« Reply #3 on: 29 September 2012, 02:10:12 »
An adjustable would work, but a much tighter fit :y
a2reed
  • Battersea London
« Reply #4 on: 29 September 2012, 02:16:44 »
Thanks for your help I will hopefully get it done... I am doing both sides and wishbones and strut top mounts and ATF in the autobox  so going to be busy .... see my other post about a stuck and very stubborn autobox sump bolt ... blooming thing!
cnj
  • ludgershall
    • 2.2 Manual CD(51 plate)
« Reply #5 on: 29 September 2012, 08:39:54 »
Depending on how long the drop links have been on you may need to have plenty of penetrating oil/spray handy. Also ref. adjustable spanner, you may not be able to get on to the flats due to the extra width ! have just done mine and they fought all the way !!!
« Reply #6 on: 29 September 2012, 08:55:50 »
It's not uncommon to have to cut them off with a disc cutter.
Also, some makes have an Allen key in the ball joint end instead. Just in case.
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #7 on: 29 September 2012, 09:06:34 »
I had to cut off the nut on one of mine with a hacksaw  :y
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #8 on: 29 September 2012, 09:50:31 »
Yeah my girlfriends Citroen ZX has those type and I had to cut both of them off, crap design  >:(
I don`t think Omega ones will be on long enough to need cutting off, I usually have to replace them every couple of years  ;D
a2reed
  • Battersea London
« Reply #9 on: 01 October 2012, 10:16:29 »
Got the old ones off eventually and will be fitting Meyle ones but notice that they don't have any flats on them to hold the shaft as you tighten the nut
Anyone had experience of these?
« Reply #10 on: 01 October 2012, 10:19:27 »
Yes, you insert an allen key into the centre of them rather than use flats.....pop some grease in the allen key recess once you have fitted them  :y
« Reply #11 on: 01 October 2012, 10:22:21 »
Yes. :)
a2reed
  • Battersea London
« Reply #12 on: 01 October 2012, 12:00:05 »
So presumably you prise out the plastic cap to get to
 the allen key???
« Reply #13 on: 01 October 2012, 12:05:14 »
the other end....as per this photo
trad style at the top, Meyle with allen key hole at bottom
a2reed
  • Battersea London
« Reply #14 on: 01 October 2012, 12:16:32 »
Well if you hadnt told me I wouldnt have noticed...thanks will check mine out
