Author Topic: Head gasket  (Read 7495 times)
Ray Austin
  • Shropshire
    • Omega 2.2 dti
Head gasket
« on: 30 September 2012, 09:22:52 »
We know someone who has an 02 plate Vauxhall omega 2.2 diesel he has had it from new and its been well looked after just over 100.000 miles that he says the head gasket has gone and he is going to send it too the breakers but he has offered to us for what he will get for it at the breakers.
To tell the truth I am not sure of the why he thinks the head gasket has gone whether the oil and coolant are mixing or the coolant sytem is over pressuring.
He took the car to the main vauxhall dealer and they told him that the head gasket has gone.
So the question is if the oil is mixing with the coolant and that the only symptom could it be the oil cooler but if it is the head gasket are these a problem to do does the the head need a skim amd new head blocks etc
Is lifting the head on these a pig to do.
Is it possible as well to get a workshop manuel for these car.
Look forward to your replys.
Ray
Re: Head gasket
« Reply #1 on: 30 September 2012, 09:30:15 »
As per your thread in Newbie section, those DTi engines are good for 300k easily, so I'd be surprised if the head gasket has gone. Its quite common for dealer to talk bull.
Either way, as before, buy it if its breaker money. Do you happen to know what spec level it is? GLS/CD/Elite ect?
If oil is mixing with coolant, could well point to oil cooler on these. Its a very simple job I believe, just 4 bolts in all I think.
Did the garage check the oil cooler?
Re: Head gasket
« Reply #2 on: 30 September 2012, 09:40:48 »
My money is on oil cooler.Afaik,they suffer similar symptoms to the v6 in that regard. ;)
Re: Head gasket
« Reply #3 on: 30 September 2012, 09:42:07 »
Quick search though, suggests a much easier job than V6!
    • 530D M Sport, 330i Coupe
Re: Head gasket
« Reply #4 on: 30 September 2012, 09:49:39 »
Oil cooler is on the n/s of the block. Not too difficult to replace.
Best to buy a Vectra B Haynes manual as this covers the DTi and there aren't too many differences between the engines.
Re: Head gasket
« Reply #5 on: 30 September 2012, 09:52:36 »
Yep,a lot easier. :y
Re: Head gasket
« Reply #6 on: 30 September 2012, 09:55:10 »
Ray, get impression from your post you do a bit of DIY work? Found this from our old site on oil cooler replacement:
remove the oil filter, drain the coolant, disconnect the two coolant hoses and then there is 4 bolts holding the heat exchanger/oil filter asembly (its all one lump) to the block, remove them and the whole lump comes off...
Clean well and fit with a new gasket
Ray Austin
  • Shropshire
    • Omega 2.2 dti
Re: Head gasket
« Reply #7 on: 30 September 2012, 11:50:52 »
Spoke to the owner this morning.
Its done 105,000 full service history and the head gasket has gone it is loosing some coolant and the coolant system is being over pressurised could it be the gasket in the inlet mamifold does coolant flow in the inlet manifold.
Is the head prone to the head cracking and it not the head gasket but the head itself.
The car has been well looked after.
Sorry for all the question and thanks for the welcome and the help.
Ray
Re: Head gasket
« Reply #8 on: 30 September 2012, 11:57:24 »
Ray
Don't want this to come across the wrong way, but its not been well looked after if the head gasket has failed. Its very rare for these to do that, they have odd issue with oil cooler and bleed off pipes, glow plugs ect. But unlike the 2.5TD (BMW lump) they don't crack heads from what I've seen here.
I'm guessing "full service history" means Vauxhall service history?
To give you an idea my fathers 2.2 petrol Omega was serviced all its life at Vauxhall, bought from fleet at end of term. Head gasket (fairly common on 2.2 petrol) failed at approx 90k.
My 2.2, also petrol & LPG'd, DIY serviced, is on 156k on its original head gasket.
Re: Head gasket
« Reply #9 on: 30 September 2012, 12:00:00 »
My advice is to buy it, if its breaker money few hundred quid?
Then get Elite Pete or Darth Loo Knee who are fairly local to you to give a look over, they will tell you whats really wrong with it  :y
Re: Head gasket
« Reply #10 on: 30 September 2012, 17:03:54 »
No coolant flows around the inlet manifold
Never heard of a head cracking on a DTi
Ray Austin
  • Shropshire
    • Omega 2.2 dti
Re: Head gasket
« Reply #11 on: 01 October 2012, 17:00:27 »
It looks like we bought the omega been to look at it. and now having to sort a few loose ends.
The coolant systen is being over pressurised and it has blown a few gasket like the thermostat gasket.
The front brake need to be looked at as it makes a noise after about 30 miles.
It looka like we will have to lift the head not that familiar with these engines done a few A serius and B as well and the k serius showing my age now ( rover).
Is there any issues with lifting the head and do I need any special tools.
Have bought the vetra manual (haynes) with the 2.2 engine is it exacly the same?
Sorry for all the question.
Ray
Ps been quoted 600.00 plus vat by local garage who do our mot to fix.
Ray Austin
  • Shropshire
    • Omega 2.2 dti
Re: Head gasket
« Reply #12 on: 03 October 2012, 17:51:59 »
Will collect the car tomorrow having to swop the insurance over and sorn our other car the primera for now.
Was going to just put the omega on our driveway and then fix the head gasket when we have a bit more time but we still have to have insurance on it unless we sorn it.
So have decided to use it it for a few weeks to see what other issues we can find with it.
Read the  vectra haynes manuel with the same engine and read that a few times looks a bit more complicated.
Is the engine the same or are there some differrences with it the vectra is FWD and the omega RWD is that the only difference.
Priced up  the cost of the bits gaskets and head bolts antifreeze  etc about £200.00.
So all we have to do is take it apart well my son can I will just supervise.
Ray
Re: Head gasket
« Reply #13 on: 03 October 2012, 18:05:49 »
very different engines sorry, chain -v- belt for starters
try seller trechii on ebay for gaskets and bolts etc
Ray Austin
  • Shropshire
    • Omega 2.2 dti
Re: Head gasket
« Reply #14 on: 03 October 2012, 18:13:25 »
I understood from other posts that the engine is the same.
Ray
