Kwaka MOT fail
Started by TheBoy, 07 October 2012, 11:27:46
What did the 1989 ZX10 fail on?
I've given it the benefit of doubt,  and not counted the things that you should have known about already such as tyres and lights :y
For the record, no air freshener on the Kwaka, before any smartass tries to upset me ::)
Can't be tyres, you never use it  ;D
As its a choice of fixing it, suggests it not quick fix like chain.
Going to go with Frame or Suspension
Seized rear suspension linkage,notchy steering head bearings,ans a few minors ?
Took mine for its test a few weeks ago.Usual tester (very sensible and noice bloke)was in a meeting, so his colleague (a well known nob) tested it.
He failed it on headlight aim slightly too high.Other bloke would have had a word and told me to adjust it down a tad when I got home,but not him.
Said he would give me a pass if I could sort it in five minutes,and loaned me a screwdriver.
I proceeded to undo all the plastic panels etc.prise them out of the way, find the correct adjuster and adjust aim,all in a blind panic.Just as he decided he was happy with the aim,I turned the bars slightly only to be greeted with a loud crack and see half my screen and the adjacent part of the top fairing (which I had previously plastic welded back into place) fly across the workshop.Everything was pressing on everything else and the strain got too much for the screen when I turned the bars.I was not fookin happy,not happy at all. >:(
Id guess fork seals and possibly headstock bearing or swing arm bearing/s :-\
ZX10 , that would be a classic now then , if its got the original exhausts maybe a hole in it  ;D
Quote from: TheBoy on 07 October 2012, 11:39:57
If you need one on a bike, you've got serious issues. :-X
Ah.. Mrs. KW says we need one in the Westfield on occasions. :-[
On a a bike as elderly as TB's ZX10, I'd go for rear suspension failure. :)
P.S..Did you change the wicks in the lights. ;D ;)
doz
Fork seals, gummed up calipers and rear shock linkage.
Go on then....how many miles has it done in the last 3 years?
treble figures?
Quote from: Jimbob on 07 October 2012, 14:19:34
treble figures?
Doubt it, barely did 2 figures between one MOT  ;D
Think i've done more in a week on the GS that he has in 5 years  ;D
Rods2
Worn rear suspension linkage, this is like Omega breathers and needs to be greased one a year.
Leaking fork seals.
Seized caliper pistons, another Kawasaki and also Yamaha favourite.
An finally the biggest reason: Furry dice hung from each mirror.  ;D ;D ;D ;D
ozzycat
Quote from: Opti on 07 October 2012, 13:53:33
TRs bike isnt old my z650 is old 1978 old v reg
long live the magic tree
its good to be back
Quote from: Rods2 on 07 October 2012, 15:33:19
Yes, errr, well, indeed, yes, uhmmmm ::)
This bike is seriously under maintained  :-[, it only ever gets fluid changes, and they aren't that common (time wise)  :-[
This is partly because I have no idea what I'm doing, and partly because the amount of space in my garage to be able to get around it is usually full of Omega bits  :-[
treble figures?
Hold the line, caller, I'll get out the MOTs...
