V6 LPG Plenum pics wanted please.
Started by 05omegav6, 07 October 2012, 11:48:39
Making a start on the injector brackets today, but am unsure where the pipes run to get from the injectors to the manifold. :-\
Any pics would be appreciated,
Ta muchly :y
No pics of V6 front end install in the lpg guides  :'(
Did look at Chris's one tother night, but twas dark and rainy ::) and I've slept since then :-X
I'll nip out and take some pics later Al. :)
The pipes just squeeze in between the top flange of the manifold and the cam covers.
That said, you have thicker pipes in your kit. Might require a rethink.
I looked at my stock of manifolds today and I have what looks like another 3.0/3.2 one. I will tap it and you are welcome to swap it for the one I bolluxed up had difficulties with when the time comes for the final fit. :y
Might take you up on that :y
Daylight hasn't improved matters, half the nozzle thread is visible through the crack :-\
Going to order some more 4mm pipe as I only have 1.3m of it and 21cm doesn't look like it will be enough tbh. So will be able to route the injector plumbing as required :y
Loom plugs entrance. Loom easily moved aside to remove bag pipes, phenom not restricted, inlet can be set aside if removed.(Before the pedants pipe up)
Bit sideways
Whoops. How did that last one get in there. ;D
Quote from: chrisgixer on 07 October 2012, 15:36:00
Aaaah! My eyes! It's too green. :o
Thanks :y
Here's this afternoons efforts, the injector assembly isn't quite as compact as yours ::)
Gas feed and injector loom will run up past the brake servo and then forward along each bank. :y
They look high, Al
Dos bonnet close OK?
Only got one pic, camera went flat ;D
High resolution one here
