Author Topic: Water in spark plugs?  (Read 1271 times)
SalahJ
  • Bedford
    • Gold 2001 Omega Elite 2.6
« on: 08 October 2012, 14:13:06 »
My miggy (2001 2.6 Elite Auto with 104K miles) vibrates a lot on cold start. It seems really rough in lower rev range, the upper rev range (4k+) seems normal. If I leave it running for 10-15 minutes, it drives OK after it gets warmed up. However, after driving it for a while it starts to vibrate a lot when idle.
It doesn't loose any coolant and a mate suspects water in plug hole. What you guys reckon?
Update: Forgot to add that engine management light comes on intermittently and the codes are 0300 and 0305 which I reckon is misfire in cylinder 5.
« Last Edit: 08 October 2012, 14:18:17 by SalahJ »
Re: Water in spark plugs?
« Reply #1 on: 08 October 2012, 14:39:29 »
its only 10 mins to whip the coil packs out and check.
we had it on ours last week we had so much rain.
« Reply #2 on: 08 October 2012, 15:07:11 »
Water or oil, or knackered coil PAC. 1,3,5 is drivers side bank, 5 is nearest bulk head.
If oil replace cam cover seals with genuine only. Clean breathers.
If water, leaking scuttle. Either wind screen seal has come adrift of its leaking in through the wiper spindle hole on that side. But a hose pipe will reveal all. :)
SalahJ
  • Bedford
« Reply #3 on: 08 October 2012, 17:00:15 »
So my mate was pretty much right. I'm gonna check it and post the update.
