Pages: [1] 2 3  All   Go Down
Author Topic: Lumpy idle  (Read 7581 times)
Radar
  • Berkshire
    • Elite 2.5 Auto
Lumpy idle
« on: 17 October 2012, 20:14:40 »
Following on from tech2 sess. at the oxford meet it threw up a code 19 so changed the crank sensor today (genuine gm from stealer) and drove for 30 minutes and the stuttering that i had whilst driving to the meet at the weekend did not come back.
But she is still a bit lumpy on idle and wondered if anyone had any ideas why? It started to absolutely tip it down so i couldn't get round to cleaning icv, egr and maf? Is there anything else worth looking at?
Also after 30 minutes drive i let her idle for a bit and could hear a tinny ticking coming from the rear / mid exhaust section but not sure (i.e. engine was warm).
Lastly there is a bracket which connects to the bulkhead from the a/c pipe with a 8mm torx screw - i think i have buggered the thread as it no longer holds tight - i dont have a die set and wondered if i can secure this another way?
Thanks
Re: Lumpy idle
« Reply #1 on: 17 October 2012, 20:32:09 »
Remind me, what work did we do on it..?
Thinking coil PAC... Perhaps..?
Abiton
Re: Lumpy idle
« Reply #2 on: 17 October 2012, 20:50:58 »
I'd start with EGR.  If it's sticking open even a tiny amount, the deep vacuum at idle will pull through a load of exhaust gas that the ECU is unaware of, causing mixture mayhem.
Re: Lumpy idle
« Reply #3 on: 17 October 2012, 20:52:20 »
Clean the ICV, as discussed
Re: Lumpy idle
« Reply #4 on: 17 October 2012, 20:53:47 »
Ah, lumpy at idle, or idle is varying....?
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #5 on: 17 October 2012, 21:03:16 »
Will clean the icv and egr and report back Thanks TB / Abiton:y (is it worth doing maf?)
Chris - I watched whilst you did cam cover gaskets on passenger side and put in new ht leads (Last christmas) :y.
I changed spark plugs, dispack and crank sensor in the last month.
P.S. I would say it is idle is varying.
« Last Edit: 17 October 2012, 21:06:08 by Radar »
Re: Lumpy idle
« Reply #6 on: 17 October 2012, 21:06:40 »
Don't touch MAF, likely to do more damage than good
Re: Lumpy idle
« Reply #7 on: 17 October 2012, 21:07:26 »
Dont clean the MAF.Its too fragile. ;)
great minds.........
fools seldom......... :D
Re: Lumpy idle
« Reply #8 on: 17 October 2012, 21:08:46 »
Ok as said then.
But don't clean maf. ;)
Unless someone knows what to clean it with without killing it...?
I don't think maf is suspect though is it...?
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #9 on: 17 October 2012, 21:12:15 »
Thankyou.
« Last Edit: 17 October 2012, 21:17:21 by Radar »
  • Chatham, Kent
    • Ghastly 1.0l Focus
Re: Lumpy idle
« Reply #10 on: 17 October 2012, 22:51:40 »
Thanks
Loctite a short length of appropriate studding(probably M5) into the thread and use a nut.
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #11 on: 17 October 2012, 22:56:46 »
Cheers Nick :y
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #12 on: 18 October 2012, 22:36:03 »
Cleaned the icv and egr valve and took for a spin. The idle holds steady for a bit then dips and engine judders and the sequence repeats itself.
Is the inside of the egr valve supposed to be silver? like the icv valve. I cleaned with wickes paint stripper and a toothbrush then let soak for 3 hours and some carbon did come out but the insides were brown (but no deposits if you know what i mean?). Should i have left it to soak for longer.
Any pointers appreciated :y
Re: Lumpy idle
« Reply #13 on: 19 October 2012, 11:16:06 »
Carb cleaner is usually fine.
Did you lubricate it? 3in1 or similar light oil. :)
Radar
  • Berkshire
    • Elite 2.5 Auto
Re: Lumpy idle
« Reply #14 on: 19 October 2012, 12:10:31 »
I cleaned the icv with carb cleaner then lightly oiled.
EGR was cleaned with paint stripper, then carb cleaner but no oiling after.
Pages: [1] 2 3  All   Go Up
