Author Topic: rocker cover  (Read 1590 times)
ste-davies
  • chester
    • vauxhall omega estate
rocker cover
« on: 25 October 2012, 21:42:46 »
hello there, was wondering can you get a metal replacement rocker cover for the x20xev? just replaced mine with a £100 one from vauxhalls and its now leaking again >:( lol, iv put gasket sealer on and made sure there torqued properly but leave it a month or two and its back to square one, lost how many times iv changed it lol
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: rocker cover
« Reply #1 on: 25 October 2012, 21:44:17 »
wheres it leaking from mate?
RIP Paul Lovejoy
martin42
Re: rocker cover
« Reply #2 on: 25 October 2012, 21:46:35 »
have you cleaned the breathers??
symes
  • oxford
    • R reg 940 volvo
Re: rocker cover
« Reply #3 on: 25 October 2012, 21:48:10 »
I know on the crap v6 if you have blocked breathers it can cause the rocker covers to leak
Re: rocker cover
« Reply #4 on: 25 October 2012, 22:01:10 »
Genuine gaskets ?
Webby the Bear
  • Northampton
Re: rocker cover
« Reply #5 on: 25 October 2012, 22:02:23 »
Genuine gaskets ?
To the op... ''are you ralf in disguise''?  ;D ;D ;D
RIP Paul Lovejoy
ste-davies
  • chester
Re: rocker cover
« Reply #6 on: 25 October 2012, 22:03:48 »
its leaking in the middle going into the plugs and i havent cleaned the small breather pipe il have a look at the weekend and the one going to the intake pipe i havent got, it was making a pool of oil at the bottom of the manifold so put one of those boy racer small k&n filters on, now its running down the engine lol, the other thing i havent tried is just nipping the bolts up a little bit, was just wondering if there is a metal replacement because there known for warping in the middle and breaking when coming off, its only a little bit at the mo but im one of these fussy ones that likes things spot on lol and i havent used a genuine gasket might get one and try it.
Webby the Bear
  • Northampton
Re: rocker cover
« Reply #7 on: 25 October 2012, 22:07:02 »
RIP Paul Lovejoy
symes
  • oxford
    • R reg 940 volvo
Re: rocker cover
« Reply #8 on: 25 October 2012, 22:08:24 »
sounds like classic breather fault-think yourself lucky not a v6 nail  :y get genuine gasket and sort breathers out and jobs a good one :y :y
jonny2112
  • Bangor NI
    • 2.6 Elite
Re: rocker cover
« Reply #9 on: 25 October 2012, 22:54:44 »
Not sure if its the same for four pots, but go easy with the sealer too.
Re: rocker cover
« Reply #10 on: 25 October 2012, 23:15:56 »
Get and fit a genuine Vx gasket and clean breathers out mate  :y  Fitting a metal rocker cover is only addressing the effect not the cause!
Re: rocker cover
« Reply #11 on: 26 October 2012, 09:01:31 »
Just to clear up a few things, covers don't warp for 4 pots. Thats just a bullshite excuse from mechanics for not doing everything right.
The gasket is leaking not the cover, you need to replace & fit gasket as per our guides. Using genuine parts and sealant, along with clean breathers and regular oil changes they gasket should last around 10 years  :y
OOF experience has proven time & again, that pattern gaskets fail much quicker.
