Pages: 1 2 [3]  All   Go Down
Author Topic: Smokeless Fuel  (Read 4126 times)
OmegaAnglesey
Re: Smokeless Fuel
« Reply #30 on: 05 December 2012, 23:49:13 »
Amazes me how they get coal thats smokeless  ;D
As a guide, we pay around 180-190 a ton for quality steam coal.
Trying to think how long a ton load would last  :-\ I would have to have it delivered in bags and stored in bags on a pallet or something ...
normally 1 ton is enough for 3 months in our winter.. assuming you only use 1 stove..
but you will need logs to burn it..  in any case you will smoke ;D
 :-\ do you mean to start it cem ?
yep.. otherwise how you will start the fire.. few newspapers wont be enough to start fire on 6-7 kgs of coal..
or acetylene torch ;D
Use fire-lighters  ::)
http://www.ebay.co.uk/itm/60-Drummer-Compact-Firelighters-Real-Fires-Stoves-BBQs-/230889105646?pt=UK_Home_Garden_Other_Fireplaces&hash=item35c21028ee
Re: Smokeless Fuel
« Reply #31 on: 05 December 2012, 23:52:34 »
this would be easier
http://www.google.com.tr/imgres?imgurl=http://www.akildakal.com/images_buyuk/f40/Asroyal-R32-Radyo-Tuplu-Soba-Sto_3640_1.jpg&imgrefurl=http://www.akildakal.com/Asroyal-R42-Radyan-Tuplu-Soba-Stoktan-Hemen-Gonderi-ucretsiz-Kargo-_3640.html&h=443&w=289&sz=40&tbnid=WFYEZB8FwJOCpM:&tbnh=90&tbnw=59&prev=/search%3Fq%3Dt%25C3%25BCpl%25C3%25BC%2Bsoba%26tbm%3Disch%26tbo%3Du&zoom=1&q=t%C3%BCpl%C3%BC+soba&usg=__e2ME7ps2eXZH1FtURm-ppssBvqo=&docid=qgcbK6PSFZEGbM&hl=tr&sa=X&ei=5hi_UIflHJSyhAeQ3IG4Aw&sqi=2&ved=0CDsQ9QEwBA&dur=437
if you can find this
http://www.google.com.tr/imgres?q=t%C3%BCp&um=1&hl=tr&safe=active&sa=N&tbo=d&rlz=1R2NDKB_enTR510&biw=980&bih=650&tbm=isch&tbnid=wSJshXvHoyx0TM:&imgrefurl=http://girnerehberi.net/kibris/tup-gaz.html&docid=ieCvrr_Ukx4LhM&imgurl=http://girnerehberi.net/kibris/wp-content/uploads/2011/02/t%2525C3%2525BCp.jpg&w=218&h=300&ei=Qhm_UL3oEsXMhAfdj4CIDw&zoom=1&iact=hc&vpx=125&vpy=102&dur=953&hovh=240&hovw=174&tx=120&ty=140&sig=114075735259467314363&page=1&tbnh=139&tbnw=103&start=0&ndsp=18&ved=1t:429,r:1,s:0,i:85
I still use it in addition to boiler :)
In this country they are very expensive to run compared to any other fuel / heater, I had a one many many years ago, but they are conveiniant and easy to use and of course, portable.... :y :y
Yep.. Bottled gas isn't really significantly different in running costs to an electric heater here, watt for watt, except with an electric heater you get all the heat you buy whereas with LPG it depends how efficiently you are burning it.
Re: Smokeless Fuel
« Reply #33 on: 06 December 2012, 00:03:49 »
These work quite well for starting a coal fire.  :)
http://www.ebay.co.uk/itm/GAS-POKER-FIRE-AND-BBQ-LIGHTER-CARTRIDGE-TYPE-/160921707716?pt=UK_Home_Garden_BBQ_Utensils_Accessories_LE&hash=item2577ae64c4
That takes me back to the 60's, grandmothers house and they had a poker plumed into the mains gas, all ready to go........... :y :y
For coal fires, twisted paper and a few sticks, soon gets it going, just wish I still had one.... ::) ::)
Re: Smokeless Fuel
« Reply #34 on: 06 December 2012, 08:36:04 »
Yep me too , times are a changing back to how they use to be years ago . Luckily its just a case of taking a few bricks out my chimney then just buying the coal basket , job done . Hopefully swmbo wont notice the big hole in the wall  ::) ;D
Re: Smokeless Fuel
« Reply #35 on: 06 December 2012, 08:45:12 »
Don't forget to get the chimney swept and smoke tested if it's been redundant for a while ;)
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
best wishes
Simon.
Re: Smokeless Fuel
« Reply #37 on: 06 December 2012, 08:51:22 »
A lit bit of paper up the chimney will do to check the draw  ;D
Get a price from these and compare........
http://www.coalmerchantsuk.co.uk/?a=northamp&kw=Northampton%20Coal%20Delivery
http://www.one-stop-diy.co.uk/Scripts/coal-northampton-delivery.htm
http://hamsonscoal.co.uk/#
Thanks for those links dad1uk , i will note them down  ;)
Re: Smokeless Fuel
« Reply #38 on: 06 December 2012, 11:19:01 »
Re: Smokeless Fuel
« Reply #39 on: 06 December 2012, 11:23:57 »
from the picture may not be visible but it flows through a multiple hole red hot ceramic .. 15 minute is enough to heat a 7x5 meters room  .. :)   I use the boiler nearly at half level.. but if I feel cold I open it ..
here electricity become ridiculously expensive after its privatized >:( >:(
Pages: 1 2 [3]  All   Go Up
