Author Topic: Water pouring in the passenger footwell!  (Read 1901 times)
davemac
  • Windsor, Berks
    • Elite 3.0 v6 auto
« on: 18 December 2012, 10:59:26 »
Hi all. Just had lots of work done on my miggy (stuff I can't do myself) and am now looking forward to doing the things I'm confident enough to do. However (lol!) after I had collected the car from the garage and taken her to get the tracking done I thought I'd run her through a car wash. As I drove my nice clean car along I heard water literally pouring into the passenger footwell!
I got the car home and had a look under the bonnet to see if any drain plugs were blocked but have not found anything so far. I had a look down below the pollen filter and that was full of soapy water!
Has anyone found this before and could perhaps give me any clues as to why the water is not running away through drain channels or plugs?
Thanks guys,
Dave.
Re: Water pouring in the passenger footwell!
« Reply #1 on: 18 December 2012, 11:00:37 »
This should help you: http://www.omegaowners.com/forum/index.php?topic=90535.0
[edit] Or this, not sure why we have two guides for the same thing: http://www.omegaowners.com/forum/index.php?topic=90582.0
« Reply #2 on: 18 December 2012, 11:05:50 »
Blocked scuttle drain.
dazza88
  • luton (bedfordshire)
    • 2001 2.6 v6 auto omega
« Reply #3 on: 18 December 2012, 11:30:04 »
Hello. I had this prob with mine but it also went in the back rear passenger at first i thought it was the mattrix until i see the pond on the rear floor so i checked the drainage and the one under the front passanger window was like a pond so i poke a mettal rod down there and it drained it out it was full of mud and leafs then flushed it through. Hope this helps
2002 2.2 cd auto             mrk2 astra gte
vauxhall colton               vauxhall omega 2.6 v6 auto
ford sierra saphire 20l   vauxhall omega 2.2 dti 02 plate
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 18 December 2012, 15:24:33 »
common problem the pollen filter drain has to be kept clear of rubbish it builds up quite quickly I now check mine at least once per month. Thought about removing the rubber plug on a permanent basis to overcome this. Not a good time for drying out carpets. This problem can also destroy the hedgehog controller on the air circ system so check drain regularly
davemac
  • Windsor, Berks
    • Elite 3.0 v6 auto
« Reply #5 on: 18 December 2012, 15:28:20 »
Thanks for all your suggestions and remedies guys, I followed all your advice and it is now draining freely. It was so full that when I removed the plug in the wheel arch I got soaked lol!
 ;D ;D ;D ;D ;D ;D ;D ;D ;D ;D
« Reply #6 on: 18 December 2012, 15:29:02 »
Remove passenger side scuttle, and pollen filter.  I use a long welding rod to poke down the drain (on left hand side of pollen filter when standing at front of car) - could also use a straightened wire coat hanger ;)
    • 530D M Sport, 330i Coupe
« Reply #7 on: 18 December 2012, 21:49:48 »
A length of 6mm twin and earth does a good job as well  :y
« Reply #8 on: 18 December 2012, 21:55:18 »
If the cabin fans start playing up in the next 6 months or so.... ;)
« Reply #9 on: 18 December 2012, 23:06:32 »
Jet wash. ::)
Page created in 0.024 seconds with 16 queries.
