Pages: [1] 2 3  All   Go Down
Author Topic: Induction Cookers - Any Good ?  (Read 6298 times)
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« on: 21 December 2012, 17:47:04 »
As above really, suppose to be more economical than Gas?, does the cookware need to be anything special or just a Magnetic Metal?
Any experiences, good or bad.
OOMV6
Re: Induction Cookers - Any Good ?
« Reply #1 on: 21 December 2012, 18:55:37 »
Yep, needs to be metal. Actual usage is limited for me, but with these and the ceramic ones, the thing to look out for is to make sure you can get 4 reasonable size pans on at the same time. Some of the rings are too small if you're cooking a big feast.
« Reply #2 on: 21 December 2012, 18:58:22 »
yes you need suitable pans. not sure on the figures, but its damn clever.
Kev has one.
« Reply #3 on: 21 December 2012, 18:59:07 »
...and yes i'm sure it will do custard ok before the purple one pipes up. ;D
« Reply #4 on: 21 December 2012, 19:29:35 »
Yes, been very pleased with ours. :y
Even more control than gas and a darn sight easier to clean.
Not all metal saucepans will work. Nothing aluminium will be suitable and a lot of stainless steel stuff won't work either. Check your pans with a magnet first. Magnet sticks? Chances are it'll work. Not an issue with us as we got a special offer with a nice set of pans thrown in. ;)
As to efficiency.. Well, you lose a lot of heat around the side with gas but the energy is a darn sight cheaper. With an induction hob the heat is split between the bottom of the saucepan and the drive electronics, so you lose a little, but not a great deal. At the end of the day, cost of cooking is insignificant anyway so swings and roundabouts.
The main advantage is that the glass stays pretty much cold, or at least, only gets a bit of conducted heat from the saucepan, so if something spills it doesn't burn and the glass doesn't tarnish. You can just remove the pan, wipe the surface and put the pan back on.
Ours has decent sized rings but you have to remember that the heat is pretty even of the whole area of the ring, unlike with a gas cooker, so if the ring is a little small you still probably have more even heating than a gas hob.
A decent induction hob is a lot more expensive than a gas hob, though. I think it's worth it and wouldn't use anything else now. YMMV. :y
Oh, and for the record, it is excellent at making custard as the extra control means you can avoid it burning on the bottom or boiling over, and, if it does, it's no issue.. It tastes.. Hmm. can't remember what it tastes like. Might have to go and make some. :-*
« Reply #5 on: 21 December 2012, 19:49:55 »
Yep, love ours. The other thing is that with decent pans you don't need them on the whole hob, you can share the hob across 2 pans and still get decent cooking :y
ozzycat
  • chudliegh knighton /devon
    • hyundia i30
« Reply #6 on: 21 December 2012, 21:07:06 »
very safe if you have little kiddies
long live the magic tree
its good to be back
« Reply #7 on: 22 December 2012, 00:31:07 »
Yes, that's another benefit. They won't even power up without a pan on, and it takes very little time for them to cool down after cooking.
« Reply #8 on: 22 December 2012, 05:51:03 »
Not too clever for people with pacemakers and heart monitors apparently :-\
« Reply #9 on: 22 December 2012, 15:26:22 »
How the hell would I know. Pink job.
I know ours is leccy, but beyond that....
zirk
  • Epping Forest
« Reply #10 on: 23 December 2012, 15:20:43 »
Thanks all, actually not for me, cant afford one,they do seem expensive, but for a friend of mine, She's managed to break, blow up 2 Electric Hobs in the last few years, now the Landlord wants to get Her an Induction Hob to replace, She was under the impression she was being palmed off with something mickey mouse but sounds like a good deal now.  :y
« Reply #11 on: 23 December 2012, 15:31:55 »
Yep, needs to be metal.  .....
Do they make pans of anything else?  ;D
When you say 'metal' ..... I assume you meant steel  ;)
« Reply #12 on: 23 December 2012, 15:33:02 »
Brilliant! SWMBO wouldn't have anything else now. If they're good enough for the top chefs .........  ;)
« Reply #13 on: 23 December 2012, 15:37:16 »
Gas is much better to cook with in my experience, nuts to how economical it is.
For induction though, pans need to have a smooth base.
« Reply #14 on: 23 December 2012, 15:38:10 »
Any cookware will work providing it has a base with magnetic properties. If not wishing to replace any/all pots & pans you can buy an "induction disc" which sits between the hob plate and pan
Pages: [1] 2 3  All   Go Up
